Updating FTD 6.2.2.1-75 to 6.2.2.2-4 - System does not show if update is applied or not
Leon1
Hello!
I updated my Firepower Threat Defense from 6.2.2.1 Build 75 to 6.2.2.2 Build 4, as this update was released yesterday.
The Update process starts and logs me off, like I expect. Then after some minutes my ping to the ASA is lost and after some minutes it comes back. So I think it reboots. After some time the web interface is reachable again.
When I log on the device, it still shows Version 6.2.2.1-75 to me. I am totally confused about this. I retried it four times, but got the same result. So I tried to find some update logs, but I didn't find them.
What I found is an empty file called "Cisco_FTD_Hotfix_AB-6.2.2.2_build_4_applied" in the directory "/var/log".
This update is related to a high risk security exploit and I need to be absolutely sure if it is applied or not. Has anybody applied it too and could confirm that something is wrong on my side or within the update?
I am also a little bit confused about the versioning in software.cisco.com.
It shows the wrong version also:
Firepower Threat Defense Hotfix 6.2.2.1
Cisco_FTD_Hotfix_AB-6.2.2.2-4.sh.REL.tar
Please help me, as my device remains offline, until this is fixed.
Cheers
Leon
28 Replies 28
Are you sure? I installed hotfix 6.2.2.2-4 (new version AN).
I have ASA version 9.8(2)135
T.
The new Version was not tried. I will download and install it. Maybe the Version is chown correclty then. I will report.
OK, but in system, I can't see new version (I see still version 6.2.2.1) :(
If I try install hotfix again, FMC show me same Firepower appliances. In FMC see old version FTD.
Did you open TAC for this issue?
T.
They did replace the hotfix version yesterday. According to their download page:
We have replaced Hotfix AC with Hotfix AN; Hotfix AB with Hotfix AO.
I am going to try to see if there is a a change in the version after this hotfix install. So far, I don't think anyone's version has changed to anything other than the one they had before.
OK, thank you. I installed last version (from yesterday).
I will wait for your info.
T.
Hey! I managed to install the new Hotfix and it changed a version, but not of the FTD.
Old hotfix:
Cisco Adaptive Security Appliance Software Version 9.8(2)12
Firepower Extensible Operating System Version 2.2(2.52)
Compiled on Thu 26-Oct-17 20:26 PDT by builders
New Hotfix:
Cisco Adaptive Security Appliance Software Version 9.8(2)135
Compiled on Fri 02-Feb-18 09:47 PST by builders
As you could see, there is a change in ASA version and in build time.
Cheers
Leon
Have patched a couple of 2110
Can confirm the ASA version is now 9.8(2)135.
The FXOS version is confirmed:
Firepower Extensible Operating System Version 2.2(2.63)
Also a new but empty file in /ngfw/var/log/ named 'Cisco_FTD_SSP_FP2K_Hotfix_AN-6.2.2.2_build_4_applied'
Same version for me now after upgrade with AN hotfix.
br, Micke
I applied this patch to 6.2.2.1-80 (on a FP2110) and this is what I get on the CLI:
but the GUI is still giving me the option to upgrade:
I do not see any of the referenced logfiles in the log directory.
Correct if I'm wrong : the update has been applied but the GUI still does "not know"...
Marcel.
Hey,
just to add to the topic,
We updated 2x 2110 from 6.2.2.1-75 to 6.2.2.2-4 via FMC and we are experiencing exactly the same issue.
After upgrade asa and os version changes but not FTD version, I also get option to "update" once again.
Nik
Same problem here.  Updated multiple times, but still shows 6.2.2.1 (80) instead of 6.2.2.2 (4).
Yes, it's correct. You can't see new version FTD in FMC. But You can verify in LINA (ASA). New hotfix upgrade only ASA code. After upgrade, you can see ASA version 9.8(2)135
Tomas
Just the amount of replies shows how careful one should when releasing patches. Just adding a remark in the release notes or just get this right in the first place would have saved me an hour of troubleshooting (mostly due to the extremely slow upgrade procedure of FTD). I'll cut Cisco some slack because this was a patch for a critical vulnerability but QA is an issue at Cisco at the moment.
Ran into this issue today doing the update to our 2120's.  Thanks to everyone here for pointing this out as I was about to waste my day calling TAC to find out what was going on here.
