Wired 802.1x Issue
AbelBurgos5029
Hello everyone,
I have been working for a while on deploying 802.1x at work. It consists of the following:
- Windows 10 workstations (using native supplicant software)
- Cisco Switch 9300 16.12.2r (Authenticator)
- Cisco ISE (Physical appliance) 2.6.0.156
Here is the issue:
I am able to login with anyone's credentials (does not matter the user it works) and it works: it authenticates against AD, Dacl is sent to switch and access is granted. But once I logout and try to login with different credentials (any credentials) it never authenticates. The NIC keeps saying "attempting to authenticate" but it never happens.
The only way to get it to re-authenticate is by bouncing the switch port.
Any ideas!?
Thank you
Abel
balaji.bandi
Can you post your config on teh switch, what you see Logs in ISE when the fail attempt take place ?
BB
Switch Port Config:
description ______
Switchport access vlan X
Switchport mode Access
power inline never
authentication control-direction in
authentication event server alive reinitialize
authentication open
authentication order dot1x
authentication priority dot1x
authentication port-control auto
authentication periodic
authentication timer restart 10
dot1x pae authenticator
dot1x timeout tx-period 10
dot1x max-req 3
spanning-tree portfast
spanning-tree bdpufilter enable
spanning-tree bdpuguard enable
On the failed logs on ISE the logs says that the supplicant abandoned the session and started a new one
>From your config, authentication open command is used which put the port in
monitor mode. This means that connectivity should be present regardless of
authentication status.
Coming to your point, can you confirm that coa is configured and working
properly? it doesn't seems kicking in hence your previous authentication
session still persists.
***** please remember to rate useful posts
Even with the authentication open command, Once I log out of one session and try to login with different credentials, it just does not authenticates; it keeps saying "attempting to authenticate" but it never does until I bounce the port.
When it comes to CoA, I am not super familiar with it. Can you point me in the right direction on how to configure this? All I have configured so far is Dacl and it works well once the authentication process is completed the first time.
