tech44048
Does anyone know where I can find technical documentation to install end of course configure one ASA behind one MX Firewall?
I need to use ASA only for Anyconnect client.
The MX firewall needs to be used as a firewall
Thanks a lot
3 Comments
balaji.bandi
You need to Open  443 port for VPN to work.
tech44048
Hi balaji,
I try to fellow this tutorial in you tube and didn't work
https://www.youtube.com/watch?v=fRc_e8nYwEQ
anyone tell me what is missing in this tutorial
Thank you
balaji.bandi
yes that should work, if that is not working we need to look the Logs in MX and what is the error you getting in client and do you see any Logs in ASA ?
