Meddane
Cisco SD-WAN Cloud On-Ramp for IaaS is a set of capabilities that extend the Cisco SD-WAN overlay fabric to a public cloud instance. This allows remote branches within the SD-WAN overlay fabric to leverage features such as Application-Aware Routing (AAR) to choose the best path to reach the applications hosted in private VPCs within a public cloud provider such as AWS, Azure, or GCP.
1-Scenarios for AWS Integration
  • SD-WAN Fabric Validation
  • Adding VPCs and Subnets in AWS
  • Creating EC2 instance in AWS
  • Adding the Cisco Catalyst 8000V Image in AWS
  • SD-WAN integration to AWS
  • Remove SD-WAN integration from AWS
2-Scenarios for GCP Integration
  • Enabling APIs and Creating a Service Account in GCP
  • Adding VPCs and Subnets in GCP
  • Creating a Virtual Machine (VM) Instance in GCP
  • SD-WAN integration to GCP
  • Remove SD-WAN integration from GCP
3-Scenarios for Azure Integration
  • Prerequisites In Azure
  • Check For Permissions To Assign Roles
  • Register An Application With Azure Active Directory (AD)
  • Assign A Role To The Application
  • Add A Resource Group, VNet, Virtual Machine In Azure Cloud
  • Integrate SD-WAN Into Microsoft Azure
  • Mapping Branch VPN To VNet(S) Tag
  • Testing Connectivity
https://dcloud2-rtp.cisco.com/content/demo/911292
1 Comment
