We are not use the 4G module on ASR 3925. Also, the router reporting
CELLWAN-4-CELLULAR_MODEM_SKU_MISMATCH
Is there a way to remotely disable the 4G module with a command rather than physicall removing the module?
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
