Edgar c Francis
EIGRP STUB
Stub routing is one way to limit queries. A stub router is one that is connected to on more than two neighbors and should be a transit router.
The EIGRP stub routing feature improve network stability, reduces resource utilization, and simplifies remote router (spoke) configuration. Stub routing is commonly used in a Hub-and-Spoke topology
 read more...
Here is the command:
R1(config-router)#EIGRP STUB ?
  connected       Do advertise connected routes
  leak-map        Allow dynamic prefixes based on the leak-map
  receive-only    Set receive only neighbor
  redistributed   Do advertise redistributed routes
  static                 Do advertise static routes
  summary         Do advertise summary routes
  • Connected means the router advertise connected routes only for those interfaces which matched with a network command.
  •  Leak-map means the router advertise only which is specified by a leak-map
  •  Receive-only means the router do not advertise any routes. And this option can be used with any other option.
  • Redistribution means the router advertise only the redistributed routes.
  • Static means the router advertise only the static routes with redistributed static command configured.
  • Summary means the router advertise only auto summarized or statically configured summary routes
NOTE: By default is connected and summary.
configuration  read more...
