Edgar c Francis
MPLS defines protocol that make different paradigm for a way routers forward packets. rather than forwarding packets based on the packets destination IP address, MPLS defines how router can forward packets based on MPLS label.
 What we are going to see in this section:
  • How MPLS work?
  • Traditional IP routing
  • Basic MPLS feature
  • MPLS terminology
1. Introduction of MPLS
2.What is MPLS Label distributing protocol (LDP) ? How LDP works?
3.how to configure MPLS LDP Peering ?
4.What is MPLS L3 VPN ? How to configure?
5.How to configure MPLS L3 VPN with RIPv2 ?
6.How to configure MPLS L3 VPN with EIGRP ?
7.How to configure MPLS L3 VPN with OSPF ?
8.What is OSPF Sham Links? how to configure OSPF Sham Links?
9.How to configure MPLS L3 with BGP AS OVERRIDE?
Let’s take an example to understand better.
  1.  host 10.1.1.1 generates and send an unlabeled packet destined to host 20.1.1.1.
  2. router 1, with no MPLS feature configured, forwards the unlabeled packet based on the destination IP address, traditional IP routing, without any labels.
  3. MPLS router e receives the unlabeled packet and decides, as part of the MPLS  forwarding process to impose(push) a new label (value 20) into the packet and forwards the packet to router 3.
  4. MPLS router 3 revives the labeled packet. router 3 swaps the label for new label value (30) and then forward the packet to router 4.
  5. MPLS router receives the labeled packet, removes (pops) the label, and forwards the packet toward router 5
  6. non-MPLS router 5 forward the unlabeled packet based on the destination IP address, as normal .
Routing protocol are used to distribute layer routing information. A forwarding decision is made based on:
  • Packet header
  • Local routing table
Routing lookup are independently perform at every hop
Basic MPLS features
MPLS is a forwarding mechanism in which packets are forwarded based on labels. MPLS packets can run other layer 2 technology such as ATM,Fame relay .PPP, Ethernet.  MPLS leverage both IP routing and CEF switching.
MPLS terminology
LSR (label switch router) any router that push label onto packet, pops label from packet, or simple forwards labeled packet. in other wards LSR forward packets based on labels and swap labels.
Edge LSP (E-LSR) Edge LSR in the MPLS network process both labeled and unlabeled
Labels IP packets (Imposes labels) and forwarded them into MPLS domain
Forwards IP packets out of the MPLS domain
A sequence of labels to reach a destination is called an lSP.
Benefits of MPLS
MPLS support multiple applications including:
Uncast and multicast IP routing
MPLS decrease forwarding overhead on core routers.
BGP free core
MPLS can support forwarding of non-IP protocol
VPN
TE
QOS
Atom
MPLS label
MPLS uses a 32-bit label header that is inserted between l2 & l3 of OSI
20-bit label
3-bit experiment field
1-bit bottom of stuck indicator
8-bit time to live field
A single label corresponds to single route and shares them with MPLS neighbor (using LDP protocol)
 MPLS label stack
Usually only one labels is assigned to a packet, but multiple labels in a label stack are supported.
These scenarios may produce more than one label:
MPLS VPN (two labels):
The top points to the egress routers, and the second label identifies the vpn.
MPLSTE (two or more labels):
The top label points to the endpoint of the traffic engineering tunnel and the second label point to the point destination.
MPLS VPNs combined with MPLSTE
Three or more labels).
