Meddane
Configuration of the basic IPv6 addressing on all routers:
R1:
interface Lo0
ipv6 address 2001:db8:1111::1/64
interface Serial1/1
no ip address
ipv6 address 2001:12::1/64
no shutd
R2:
interface Lo0
ipv6 address 2002:db8:2222::2/64
interface Serial1/1
no ip address
ipv6 address 2001:12::2/64
no shutd
interface Serial1/0
no ip address
ipv6 address 2001:23::2/64
no shutd
R3:
interface Lo0
ipv6 address 2003:db8:3333::3/64
interface Serial1/2
no ip address
ipv6 address 2001:34::3/64
no shutd
interface Serial1/1
no ip address
ipv6 address 2001:23::3/64
no shutd
R4:
interface Lo0
ipv6 address 2004:db8:4444::4/64
interface Serial1/1
no ip address
ipv6 address 2001:34::4/64
no shutd
Configure OSPFv3 on R1 and R2. Enable OSPFv3 for the WAN interfaces of R1 and R2. Do NOT advertise R1 or R2’s LAN subnet using OSPFv3. Ensure that R1s LAN subnet is advertised as an external Type 1 LSA. Verify the configuration using the appropriate commands.
R1:
ipv6 router ospf 1
router-id 1.1.1.1
redistribute connected metric-type 1
interface serial 1/1
ipv6 ospf 1 area 0
R2:
ipv6 router ospf 1
router-id 2.2.2.2
ipv6 ospf 1 area 0
Verification of OSPFv3 adjacencies:
R2#show ipv6 ospf neighbor
            OSPFv3 Router with ID (2.2.2.2) (Process ID 1)
Neighbor ID     Pri   State           Dead Time   Interface ID    Interface
1.1.1.1           0   FULL/  -        00:00:34    5               Serial1/1
R1#show ipv6 ospf neighbor
            OSPFv3 Router with ID (1.1.1.1) (Process ID 1)
2.2.2.2           0   FULL/  -        00:00:32    5               Serial1/1
Next, verify OSPFv3 redistribution by looking at the external LSA Type-5 entry in the LSDB:
R2 receives an LSA Type 5 from R1 toward the prefix 2001:DB8:1111::/64 :
R2#show ipv6 ospf database external
                Type-5 AS External Link States
  Routing Bit Set on this LSA
  LS age: 313
  LS Type: AS External Link
  Link State ID: 0
  Advertising Router: 1.1.1.1
  LS Seq Number: 80000001
  Checksum: 0x189B
  Length: 36
  Prefix Address: 2001:DB8:1111::
  Prefix Length: 64, Options: None
  Metric Type: 1 (Comparable directly to link state metric)
  Metric: 20
Configure MP-BGP on R2, R3 and R4. All routers should use Link Local addresses for peering and establishing MP-BGP sessions. Verify your configuration
It is important to know that when using a Link Local address for peering, we need use the neighbor "link-local address" update-source "interface" command to ensure that the session will be established because Link-Local addresses are specific to interfaces. This is specific only when using Link-Local addresses for peering.
Another point important to remember is that in BGP Link local address cannot be used by default for making BGP neighborship to ensure peering using link-local address, it needs %Interface with exact case, the example is shown on R2:
R2(config-router)#bgp router-id 2.2.2.2
R2(config-router)#neighbor FE80::C802:1BFF:FEE0:8 remote-as 234
% BGP(v6): Invalid scope. Unable to configure link-local peer.
R2(config-router)#
R2(config-router)#! (In BGP Link local address can not be used by default
R2(config-router)#!  for making BGP neighborship)
R2(config-router)#
R2(config-router)#! to ensure peering using link-local address
R2(config-router)#! need %Interface with exact case
R2(config-router)#
R2(config-router)#neighbor FE80::C802:1BFF:FEE0:8%Serial1/0 remote-as 234
R2(config-router)#
Now let's configure MP-BGP as required:
R2 :
router bgp 234
neighbor FE80::C802:1BFF:FEE0:8 update-source serial 1/0
R3 :
router bgp 234
bgp router-id 3.3.3.3
address-family ipv6
neighbor FE80::C801:EFF:FEBC:8%Serial1/1 remote-as 234
neighbor FE80::C801:EFF:FEBC:8 update-source serial 1/1
neighbor FE80::C803:1BFF:FEE0:8%Serial1/2 remote-as 234
neighbor FE80::C803:1BFF:FEE0:8 update-source serial 1/2
R4 :
router bgp 234
bgp router-id 4.4.4.4
address-family ipv6
neighbor FE80::C802:1BFF:FEE0:8%Serial1/1 remote-as 234
neighbor FE80::C802:1BFF:FEE0:8 update-source serial 1/1
Verify your configuration using the show bgp ipv6 unicast summary command:
R2#show bgp ipv6 unicast summary
BGP router identifier 2.2.2.2, local AS number 234
BGP table version is 1, main routing table version 1
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
                4          234      12      13        1    0    0 00:09:32        0
R3#show bgp ipv6 unicast summary
BGP router identifier 3.3.3.3, local AS number 234
                4          234      14      14        1    0    0 00:10:42        0
                4          234      14      14        1    0    0 00:10:18        0
R4#show bgp ipv6 unicast summary
BGP router identifier 4.4.4.4, local AS number 234
                4          234      16      15        1    0    0 00:11:54        0
Advertise the LAN subnets of R1, R2, and R3 via MP-BGP. Verify your configuration.
To ensure that R2 and R4 do see each others' LAN subnets in their respective BGP RIBs, R3 must be configured as a route reflector. This task is completed as follows:
R1:
router bgp 234
address-family ipv6
network 2002:db8:2222::/64
R3:
router bgp 234
address-family ipv6
network 2003:db8:3333::/64
R4:
router bgp 234
address-family ipv6
network 2004:db8:4444::/64
Let's verify the BGP RIB table with the show bgp ipv6 unicast command on all routers:
It is important to remember that the loop prevention mechanism IBGP says: Do not advertise iBGP-learned routes to iBGP peers.
This is why R2 and R4 do not learn the prefixes 2004:DB8:4444::/64 and 2002:DB8:2222::/64 respectively.
BGP table version is 3, local router ID is 2.2.2.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
 *>  2002:DB8:2222::/64
                       ::                       0         32768 i
 *>i 2003:DB8:3333::/64
                                                0    100      0 i
BGP table version is 4, local router ID is 3.3.3.3
 *>i 2002:DB8:2222::/64
                                                0    100      0 i
 *>  2003:DB8:3333::/64
                       ::                       0         32768 i
 *>i 2004:DB8:4444::/64
                                                0    100      0 i
BGP table version is 3, local router ID is 4.4.4.4
                                                0    100      0 i
 *>  2004:DB8:4444::/64
                       ::                       0         32768 i
The following outputs shown the details of the BGP routes:
R2#show bgp ipv6 unicast 2002:db8:2222::/64
BGP routing table entry for 2002:DB8:2222::/64, version 2
Paths: (1 available, best #1, table default)
  Advertised to update-groups:
  Refresh Epoch 1
  Local
    :: from 0.0.0.0 (2.2.2.2)
      Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
      rx pathid: 0, tx pathid: 0x0
R3#show bgp ipv6 unicast 2003:db8:3333::/64
BGP routing table entry for 2003:DB8:3333::/64, version 3
  Refresh Epoch 1
  Local
    :: from 0.0.0.0 (3.3.3.3)
R4#show bgp ipv6 unicast 2004:DB8:4444::/64
BGP routing table entry for 2004:DB8:4444::/64, version 3
  Refresh Epoch 1
  Local
    :: from 0.0.0.0 (4.4.4.4)
Redistribute between MP-BGP and OSPFv3 on R2. Ensure that ONLY the LAN subnets are redistributed.
By default, when redistributing between IPv6 routing protocols, connected subnets will not be included requiring the adding of the include-connected keyword.
In our case we redistribute the connected R2 LAN subnet into OSPF using a route map to match only this subnet to be redistributed.
We have two caveats here when redistributing between BGP and OSPF:
1-when OSPF routes are redistributed into BGP, only internal routes are redistributed. So we need redistribute ospf 1 match external 1 command under router bgp on R2, in order to redistribute the prefix 2001:DB8:1111::/64 advertised earlier by R1 as an external Metric-Type 1 route
2-when BGP routes are redistributed into an IGP, only EBGP routes are redistributed .So we need bgp redistribute-internal command under router BGP on R2 to allow the redistribution of the subnets learned from the IBGP peers.
R2:
route-map LO0-R2 permit 10
match interface loopback0
route-map LO0-R2 deny 20
ipv6 router ospf 1
redistribute connected route-map LO0-R2
redistribute bgp 234
router bgp 234
address-family ipv6
Let's verify the configuration by looking at the LSDB on either R1 or R2 for the routes redistributed from BGP-to-OSPF:
R2 creates two LSA Type 5 for the prefixes 2003:DB8:3333::/64 and 2002:DB8:2222::/64 and advertises these LSAs to R1.
Remember that the prefix 2004:DB8:4444:: which is the LAN's R4 is not yet learned because the IBGP loop-prevention mechanism.
R2#show ipv6 ospf database external self-originate
  LS age: 71
  Link State ID: 0
  Advertising Router: 2.2.2.2
  Checksum: 0xCDAA
  Length: 36
  Prefix Address: 2003:DB8:3333::
  Metric Type: 2 (Larger than any link state path)
  Metric: 1
  LS age: 71
  Link State ID: 1
  Checksum: 0x196E
  Length: 36
  Prefix Address: 2002:DB8:2222::
  Metric: 20
R1 receives successfully two external routes toward the prefixes 2003:DB8:3333::/64 and 2002:DB8:2222::/64:
R1#show ipv6 route ospf
IPv6 Routing Table - default - 7 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
       B - BGP, R - RIP, H - NHRP, I1 - ISIS L1
       I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary, D - EIGRP
       EX - EIGRP external, ND - ND Default, NDp - ND Prefix, DCE - Destination
       NDr - Redirect, O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1
       OE2 - OSPF ext 2, ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2, l - LISP
OE2 2002:DB8:2222::/64 [110/20]
     via FE80::C801:EFF:FEBC:8, Serial1/1
OE2 2003:DB8:3333::/64 [110/1]
Let's verify OSPF-to-BGP redistribution by looking at the MP-BGP RIB:
BGP table version is 4, local router ID is 2.2.2.2
 *>  2001:DB8:1111::/64
                       FE80::C800:EFF:FEBC:8
                                               84         32768 ?
                       ::                       0         32768 i
                                                0    100      0 i
                                                0    100      0 i
                       ::                       0         32768 i
                                                0    100      0 i
Configure your network so that all routers can ping each others' LAN subnets from their own local LAN subnet, i.e. LAN-to-LAN pings. Verify your configuration using extended ping. When completing this task, follow the restrictions below:
You are NOT allowed to enable an IGP within AS 234
You are NOT allowed to configure static routes on R2, R3 and R4
You are NOT allowed to create any tunnels
You are NOT allowed to advertise the WAN prefixes via BGP
You are NOT allowed to use MP-BGP default routing
First, it is important to recall that when peering using Link Local addresses, you must use a route map to specify the global Unicast address as the next hop address for the UPDATE messages sent by the local router. To complete this first part, implement the following configuration on R1, R2 and R3:
R2:
route-map NEXT-HOP permit 10
set ipv6 next-hop 2001:23::2
router bgp 234
address-family ipv6
neighbor FE80::C802:1BFF:FEE0:8 route-map NEXT-HOP out
R3:
route-map R2-NEXT-HOP permit 10
set ipv6 next-hop 2001:23::3
route-map R4-NEXT-HOP permit 10
set ipv6 next-hop 2001:34::4
router bgp 234
address-family ipv6
neighbor FE80::C801:EFF:FEBC:8 route-map R2-NEXT-HOP out
neighbor FE80::C803:1BFF:FEE0:8 route-map R4-NEXT-HOP out
R4:
router bgp 234
address-family ipv6
Following NEXT_HOP modification, you remember the normal iBGP-to-iBGP advertisement rules. By default, R3 will not advertise prefixes received from R2 to R4 and vice-versa. To override this issue, R3 must be configured as a route reflector as follows:
R3:
router bgp 234
address-family ipv6
neighbor FE80::C801:EFF:FEBC:8 route-reflector-client
neighbor FE80::C803:1BFF:FEE0:8 route-reflector-client
The LSDB on R1 and the MP-BGP RIBs on R2, R3, and R4 shown the entries required to be inserted to ensure the LAN-to-LAN connectivity:
R1#show ipv6 ospf database
                Router Link States (Area 0)
ADV Router       Age         Seq#        Fragment ID  Link count  Bits
 1.1.1.1         1837        0x80000008  0            1           E
 2.2.2.2         1607        0x80000008  0            1           E
                Link (Type-8) Link States (Area 0)
ADV Router       Age         Seq#        Link ID    Interface
 1.1.1.1         1837        0x80000007  5          Se1/1
 2.2.2.2         1856        0x80000007  5          Se1/1
                Intra Area Prefix Link States (Area 0)
ADV Router       Age         Seq#        Link ID    Ref-lstype  Ref-LSID
 1.1.1.1         1837        0x80000007  0          0x2001      0
 2.2.2.2         1856        0x80000007  0          0x2001      0
ADV Router       Age         Seq#        Prefix
 1.1.1.1         1837        0x80000007  2001:DB8:1111::/64
 2.2.2.2         56          0x80000004  2003:DB8:3333::/64
 2.2.2.2         1607        0x80000002  2002:DB8:2222::/64
 2.2.2.2         60          0x80000001  2004:DB8:4444::/64
R1 receives the three subnets of R2 R3 and R4:
R1#show ipv route ospf
IPv6 Routing Table - default - 8 entries
OE2 2004:DB8:4444::/64 [110/1]
BGP table version is 10, local router ID is 2.2.2.2
                                               84         32768 ?
                       ::                       0         32768 i
                       2001:23::3               0    100      0 i
BGP table version is 13, local router ID is 3.3.3.3
 *>i 2001:DB8:1111::/64
                       2001:23::2              84    100      0 ?
                       2001:23::2               0    100      0 i
                       ::                       0         32768 i
                       2001:34::4               0    100      0 i
BGP table version is 12, local router ID is 4.4.4.4
                       2001:34::4              84    100      0 ?
                       ::                       0         32768 i
R4#
R4#show ipv6 route bgp
B   2001:DB8:1111::/64 [200/84]
     via FE80::C802:1BFF:FEE0:8, Serial1/1
B   2002:DB8:2222::/64 [200/0]
B   2003:DB8:3333::/64 [200/0]
The ping LAN-to-LAN between all routers are success full:
R1#ping 2002:db8:2222::2 sou lo0
Sending 5, 100-byte ICMP Echos to 2002:DB8:2222::2, timeout is 2 seconds:
Packet sent with a source address of 2001:DB8:1111::1
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/65/100 ms
R1#
R1#ping 2003:db8:3333::3 sou lo0
Sending 5, 100-byte ICMP Echos to 2003:DB8:3333::3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 64/96/144 ms
R1#
R1#ping 2004:db8:4444::4 sou lo0
Sending 5, 100-byte ICMP Echos to 2004:DB8:4444::4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 100/114/132 ms
R1#
R2#ping 2001:db8:1111::1 sou lo0
Sending 5, 100-byte ICMP Echos to 2001:DB8:1111::1, timeout is 2 seconds:
Packet sent with a source address of 2002:DB8:2222::2
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/84/116 ms
R2#
R2#ping 2003:db8:3333::3 sou lo0
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/54/128 ms
R2#
R2#ping 2004:db8:4444::4 sou lo0
Success rate is 100 percent (5/5), round-trip min/avg/max = 72/95/152 ms
R2#
R3#ping 2001:db8:1111::1 sou lo0
Packet sent with a source address of 2003:DB8:3333::3
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/88/148 ms
R3#
R3#ping 2002:db8:2222::2 sou lo0
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/67/148 ms
R3#
R3#ping 2004:db8:4444::4 sou lo0
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/67/100 ms
R3#
R4#ping 2001:db8:1111::1 sou lo0
Packet sent with a source address of 2004:DB8:4444::4
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/95/140 ms
R4#
R4#ping 2002:db8:2222::2 sou lo0
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/84/124 ms
R4#
R4#ping 2003:db8:3333::3 sou lo0
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/28/40 ms
R4#
