Meddane
Basic configuration of all routers:
R1:
ipv6 unicast-routing
interface FastEthernet0/0
 ipv6 address 2012:12::1/64
 ipv6 enable
 ospfv3 1 ipv6 area 0
 no shut
router ospfv3 1
 address-family ipv6 unicast
  router-id 2.2.2.2
 exit-address-family
R2:
 ipv6 address 2012:12::2/64
 ipv6 enable
 no shut
interface Serial1/0
 ipv6 address 2023:23::2/64
 ipv6 enable
 ospfv3 1 ipv6 area 23
 no shut
router ospfv3 1
  router-id 2.2.2.2
 exit-address-family
R3:
interface Serial1/0
 ipv6 address 2023:23::3/64
 ipv6 enable
 no shut
interface Serial1/1
 ipv6 enable
 ipv6 rip RIP enable
 no shut
ipv6 router rip RIP
 redistribute ospf 1 metric 5 include-connected
router ospfv3 1
  router-id 3.3.3.3
  redistribute rip RIP include-connected
 exit-address-family
R3 is an ASBR and redistributes between RIPng and OSPFv3.
R2 is an ABR.
To advertise external routes into OSPF, the ASBR creates two LSAs Type 5 to describe a path to a prefixes external 2004:4::/64 and 2034:34::/64 :
The Link State ID of an LSA 5 does not list the ipv6 addresses unlike with OSPFv2,instead this LSID represent the number of the instance,it is used to distinguish multiple external LSAs that are originated by the same ASBR.
In this case ,since we have two LSA 5 ,we have two instances:LSID=0 for the the LSA's prefix 2004:4::/64,the LSID=1 for the LSA 5's prefix 2034:34::/64.
The prefixes 2004:4::/64 and 2034:34::/64 are described in the "PrefixLength" and "Prefix Address" fields:
R2#show ipv6 ospf database external
            OSPFv3 Router with ID (2.2.2.2) (Process ID 1)
                Type-5 AS External Link States
  Routing Bit Set on this LSA
  LS age: 392
  LS Type: AS External Link
  Link State ID: 0
  Advertising Router: 3.3.3.3
  LS Seq Number: 80000001
  Checksum: 0x6F19
  Length: 36
  Prefix Address: 2004:4::
  Prefix Length: 64, Options: None
  Metric Type: 2 (Larger than any link state path)
  Metric: 20
  LS age: 344
  Link State ID: 1
  Checksum: 0x4ADC
  Length: 36
  Prefix Address: 2034:34::
  Metric: 20
R2#
At the end ,in OSPFv3 's LSA Type 5,the Forward Address does not appear because it is now optional.The forwarding address is present in the AS-external-LSA if and only if the AS-external-LSA's bit F is set.
To ensure the reachability of an ASBR into other areas, the ABR R2 creates an LSA Type 4 renamed "inter-area router LSA" (on OSPFv2 ,the LSA 4 is called : ASBR-summary LSA):
-The Link State ID of an inter-area router LSA is no longer the router-ID of the ASBR ,this field represents an instance and it is used to distinguish multiple inter- area router LSAs that are originated by the same ABR.  The Router-ID of the ASBR is displayed at the end of the LSA 4,in the "Destination Router ID" field.
-"Metric: 64" is the ABR's cost to reach the ASBR.
R2#show ipv6 ospf database inter-area router
                Inter Area Router Link States (Area 0)
  LS age: 1939
  Options: (V6-Bit, E-Bit, R-bit, DC-Bit)
  LS Type: Inter Area Router Links
  Link State ID: 50529027
  Advertising Router: 2.2.2.2
  Checksum: 0x277F
  Length: 32
  Metric: 64
  Destination Router ID: 3.3.3.3
R2#
R1 examines the external LSAs. It first examines the external LSAs Type 5 created by the ASBR R3 for the prefixes 2004:4::/64 and 2034:34::/64,then it calculates how to reach the ASBR. R1 examines the inter-area router LSA Type 4 to reach R3, this LSA Type 4 is created by the ABR R2. After doing so, R1 knows that the ASBR R3 is reachable through the ABR R2. Therefore, R1 installs a routes toward 2004:4::/64 and 2034:34::/64 its routing table as an E1 routes so the metric for is R1's metric to reach the ABR R2 which is 1 as shown by the show ip ospf border-routers, plus the ABR's metric to reach the ASBR R3 which is listed in the inter-area router LSA 4 =64 , plus the metric of the external LSA which 20 listed in the LSA Type 5 advertised by the ASBR R3,in other word: 1+64+20=85,as shown by the show ipv6 route ospf:
R1#show ipv6 ospf border-routers
            OSPFv3 Router with ID (1.1.1.1) (Process ID 1)
Codes: i - Intra-area route, I - Inter-area route
i 2.2.2.2 [1] via FE80::C801:19FF:FE0C:8, FastEthernet0/0, ABR, Area 0, SPF 9
I 3.3.3.3 [65] via FE80::C801:19FF:FE0C:8, FastEthernet0/0, ASBR, Area 0, SPF 9
R1#
R1#show ipv6 route ospf
IPv6 Routing Table - default - 6 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
       B - BGP, R - RIP, H - NHRP, I1 - ISIS L1
       I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary, D - EIGRP
       EX - EIGRP external, ND - ND Default, NDp - ND Prefix, DCE - Destination
       NDr - Redirect, O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1
       OE2 - OSPF ext 2, ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2, l - LISP
OE1 2004:4::/64 [110/85]
OI  2023:23::/64 [110/65]
OE1 2034:34::/64 [110/85]
R1#
Let's see the Router LSA-1:
The line "Area Border Router" in the LSA Type 1 of R2 means that the Bit B is set in this LSA indicating that this router R2 is an ABR:
R2#show ipv ospf data router self-originate | begin Area 23
                Router Link States (Area 23)
  LS age: 145
  LS Type: Router Links
  Link State ID: 0
  LS Seq Number: 80000006
  Checksum: 0xBAE4
  Length: 40
  Area Border Router
  Number of Links: 1
    Link connected to: another Router (point-to-point)
      Link Metric: 64
      Local Interface ID: 4
      Neighbor Interface ID: 3
      Neighbor Router ID: 3.3.3.3
R2#
The line "AS Boundary Router" in the LSA Type 1 of R3 means that the Bit E is set in this LSA indicating that this router R3 originates external LSAs:
R2#show ipv6 ospf database router adv-router 3.3.3.3
  LS age: 1386
  Link State ID: 0
  LS Seq Number: 80000004
  Checksum: 0x554B
  Length: 40
  AS Boundary Router
  Number of Links: 1
      Link Metric: 64
      Local Interface ID: 3
      Neighbor Interface ID: 4
      Neighbor Router ID: 2.2.2.2
R2#
-In both LSAs 1 the Link State ID = 0 represents the first fragment ,if we add another router and connect this router to R2 in area 23 then R2 originates a separate router LSA 1 with a different Link State ID (Link State ID = 1) to describe the connection to link shared with this router.
-On OSPFv3 the Router LSAs 1 have no address or prefixe informations and routes for stub networks does not appear in the LSA Type 1.Rather, they are included in intra-area prefix LSAs called LSA Type 9.
In the LSA 1 of R2 :
-Local Interface ID: 4 is R2's Interface ID for the link R2--R3
-Neighbor Interface ID: 3 is R3 's Interface ID for the link R2--R3
In the LSA 1 of R3 :
-Local Interface ID: 3 is R3's Interface ID for the link R2--R3
-Neighbor Interface ID: 4 is R2 's Interface ID for the link R2--R3
The new LSAs Type 8 called Link-LSAs provide the router's link-local address to all other routers attached to the link(because the link-local address is used as the next-hop for ospf routes).
And they inform other routers attached to the link of a list of IPv6 prefixes associated with the link.
Let's examine the LSA Type 8 created by R2 in area 23:
-"The "Link State ID: 4" represents the R2's Interface ID for the link R2--R3 listed in the LSA Type 1'R2.
-"Link Local Address: FE80::C801:19FF:FE0C:8" represents the Link-local address of s1/1'R2 which will be used as the next-hop by R3 for all routes learned from R2.
-"Prefix Address: 2023:23::" represents the prefix attached to its interface in area 23 with the Prefix Length: 64.
R2#show ipv6 ospf database link Self-originate | begin Area 23
                Link (Type-8) Link States (Area 23)
  LS age: 1260
  LS Type: Link-LSA (Interface: Serial1/0)
  Link State ID: 4 (Interface ID)
  LS Seq Number: 80000005
  Checksum: 0x23B9
  Length: 56
  Router Priority: 1
  Number of Prefixes: 1
R2#
Let's examine the LSA Type 8 created by R3 in area 23:
-The "Link State ID: 3" represents the R3's Interface ID for the link R2--R3 listed in the LSA Type 1'R3.
-Link Local Address: FE80::C802:16FF:FE60:0 represents the Link-local address of s1/1'R3 which will be used as the next-hop by R2 for all routes learned from R3.
-Prefix Address: 2023:23:: represents the prefix attached to its interface in area 23 with the Prefix Length: 64.
R3#show ipv6 ospf database link self-originate
            OSPFv3 Router with ID (3.3.3.3) (Process ID 1)
  LS age: 1638
  Link State ID: 3 (Interface ID)
  Checksum: 0xD1BD
  Length: 56
  Router Priority: 1
R3#
Let's see the Network LSA Type-2:
In the Link R1---R2 , R2 is the DR and originates an LSA Type 2 (Network LSA) :
-The Link State ID is set to the Interface ID of the Designated Router on the link rather than the address of Designated Router on OSPFv2.
-In OSPFv3 the LSA Type 2 does not contain a Network Mask unlike on OSPFv2. All prefix informations are carried over the intra-Area Prefix LSAs (LSA Type 9) originated by the Designated Router in the Link.
R2#show ipv6 ospf database network
                Net Link States (Area 0)
  LS age: 465
  LS Type: Network Links
  Link State ID: 2 (Interface ID of Designated Router)
  LS Seq Number: 80000003
  Checksum: 0x13DD
  Length: 32
        Attached Router: 2.2.2.2
        Attached Router: 1.1.1.1
The new LSA Type 9 (intra-Area Prefix LSA) is used to associate a list of IPv6 address prefixes with a transit network link by referencing the LSA Type 2(Network LSAs) and a list of IPv6 address prefixes with a router by referencing the LSA Type 1 (Router LSA).
Let's examine the LSAs Type 9 on R2:
-The LSA Type 9 created in area 0 lists the Referenced Link State ID: 2 which is the Link State ID of the LSA Type 2 created by the DR R2 and the  Referenced LSA Type: 2002 which the network LSA 2.
-The LSA Type 9 created in area 23 lists the Referenced Link State ID: 0 which is the Link State ID of the LSA Type 1 created by R2 and the Referenced LSA Type: 2001 which is the router LSA 1.
R2#show ipv6 ospf database prefix self-originate
                Intra Area Prefix Link States (Area 0)
  LS age: 121
  LS Type: Intra-Area-Prefix-LSA
  Link State ID: 2048
  Checksum: 0x2144
  Length: 44
  Referenced Advertising Router: 2.2.2.2
  Prefix Address: 2012:12::
  Prefix Length: 64, Options: None, Metric: 0
                Intra Area Prefix Link States (Area 23)
  LS age: 379
  Link State ID: 0
  Checksum: 0xAC5F
  Length: 44
  Prefix Length: 64, Options: None, Metric: 64
R2#
Analysing the LSA Type 9 created for area 0:
-In the LSA Type 9 created in area 0 where a Designated Router is elected,the DR R2 originates an intra-area-prefix LSA-9 to advertise the link's prefixes throughout the area.
-For a link R1--R2, the DR R2 builds an intra-area-prefix-LSA in order to indicate the prefixes associated with the Link, the fields Referenced LSA Type, Referenced Link State ID, and Referenced Advertising Router are set to the corresponding fields of the Network LSA Type 2 (Link State ID,and Advertising Router respectively) created by the DR R2 and shown earlier.
-This means that the Referenced LS Type is set to 0x2002 (Network LSA-2), the Referenced Link State ID is set to the Interface ID of the Designated Router on the Link which is 2 ,and the Referenced Advertising Router is set to the Router ID of Designated Router 2.2.2.2
Analyzing the LSA Type 9 created for area 23:
-In the LSA Type 9 created in area 23 where there is no DR, R2 builds an intra-area prefix LSA-9 to advertise prefixes for its attached stub links, loopback interfaces and hosts.
-This LSA 9 is created in order to indicate the prefixes are to be associated with the Router R2 itself,R2 sets the Referenced LS Type to 0x2001 (Router LSA), the Referenced Link State ID to 0 which is the LSID of the its LSA Type 1 shown earlier , and the Referenced Advertising Router to its own router-ID 2.2.2.2
-On OSPFv2,the SPF calculations are triggered by the LSA Type 1 and the LSA Type 2 when a change occurs.
-Since on OSPFv3 the LSA Type 1 and Type 2 do not carry the prefix informations :adding or removing the subnets in the OSPF does not trigger SPF calculation like what we have learned about OSPFv2,so the purpose of separating the prefix information from the LSA Type 1 and Type 2 and adding two LSAs Type 8 and Type 9 to carry these prefixes is to optimize the convergence of OSPFv3.
