Edgar c Francis
Generic Routing Encapsulation (GRE) is a network tunneling protocol developed by Cisco Systems that can encapsulate a wide variety of network layer protocols inside virtual point-to-point links or point-to-multipoint links over an Internet Protocol network.
When we use GRE?
GRE is used when packets need to be sent from one network to another over the internet.
Generic Routing Encapsulation (GRE) has some disadvantages:-
GRE tunnel is an encapsulation protocol and does not perform any encryption.
When we create a GRE point-to-point tunnel without any encryption is extremely risky as sensitive data can easily be extracting from the tunnel and misused by others. ( That’s the reason we used IPSec to add an encryption layer and secure the GRE tunnel with the help of IPSec we get army-level encryption).
 Classic GRE tunnel is a point to point, Manual tunnel, Not scalable, Static IP on all endpoints
GRE tunnel uses a ‘tunnel’ interface a logical interface configured on the router with an IP address where packets are encapsulated and decapsulate as they enter or exit the GRE tunnel.
All tunnel interfaces of participated routers must always be configured with an IP address that is not used anywhere else in the network. Each tunnel interface is assigned an IP address within the same network as other Tunnel interfaces. Before you configure you must adjust (MTU) maximum transfer unit and MSS maximum segment size.
Let see the configuration:-
Topology_
Goal:
  • configure the topology as per the diagram.
  • assign IP addresses respectively to their interfaces as per the topology.
  • configure default and static routing.
  • configure point-to-point tunnels between router 1 to 3 and router 1 to router 4
R1(config)#interface serial 4/0
R1(config-if)#ip address 1.1.1.1 255.0.0.0
R1(config-if)#no shutdown
R1(config-if)#interface fastethernet 0/0
R1(config-if)#ip address 10.1.1.1 255.0.0.0
R1(config-if)#no keepalive
R1(config-if)#exit
R2(config)#interface serial 4/0
R2(config-if)#ip address 1.1.1.2 255.0.0.0
R2(config-if)#no shutdown
R2(config-if)#interface serial 4/1
R2(config-if)#ip address 3.3.3.1 255.0.0.0
R2(config-if)#interface serial 4/2
R2(config-if)#ip address 4.4.4.1 255.0.0.0
R2(config-if)#interface fastethernet 0/0
R2(config-if)#ip address 20.1.1.1 255.0.0.0
R2(config-if)#no keepalive
R2(config-if)#exit
R3(config)#interface serial 4/1
R3(config-if)#ip address 3.3.3.2 255.0.0.0
R3(config-if)#no shutdown
R3(config-if)#interface fastethernet 0/0
R3(config-if)#ip address 30.1.1.1 255.0.0.0
R3(config-if)#no keepalive
R3(config-if)#exit
R4(config)#interface serial 4/2
R4(config-if)#ip address 4.4.4.2 255.0.0.0
R4(config-if)#no shutdown
R4(config-if)#interface fastethernet 0/0
R4(config-if)#ip address 40.1.1.1 255.0.0.0
R4(config-if)#no keepalive
R4(config-if)#exit
R1#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        10.1.1.1        YES manual up                    up
Serial4/0                    1.1.1.1         YES manual up                    up
R2#show ip interface brief
FastEthernet0/0        20.1.1.1        YES manual up                    up
Serial4/0                    1.1.1.2         YES manual up                    up
Serial4/1                    3.3.3.1         YES manual up                    up
Serial4/2                    4.4.4.1         YES manual up                    up
R3#show ip interface brief
FastEthernet0/0        30.1.1.1        YES manual up                    up
Serial4/1                    3.3.3.2         YES manual up                    up
R4#show ip interface brief
FastEthernet0/0        40.1.1.1        YES manual up                    up
Serial4/2                    4.4.4.2         YES manual up                    up
R1(config)#ip route 0.0.0.0 0.0.0.0 serial 4/0
R1(config)#exit
R2(config)#ip route 1.0.0.0 255.0.0.0 serial 4/0
R2(config)#ip route 10.0.0.0 255.0.0.0 serial 4/0
R2(config)#ip route 30.0.0.0 255.0.0.0 serial 4/1
R2(config)#ip route 3.0.0.0 255.0.0.0 serial 4/1
R2(config)#ip route 4.0.0.0 255.0.0.0 serial 4/2
R2(config)#ip route 40.0.0.0 255.0.0.0 serial 4/2
R2(config)#exit
R3(config)#ip route 0.0.0.0 0.0.0.0 serial 4/1
R3(config)#exit
R4(config)#ip route 0.0.0.0 0.0.0.0 serial 4/2
R1#ping 20.1.1.1
Sending 5, 100-byte ICMP Echos to 20.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/33/60 ms
R1#ping 30.1.1.1
Sending 5, 100-byte ICMP Echos to 30.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/38/68 ms
R1#ping 40.1.1.1
Sending 5, 100-byte ICMP Echos to 40.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/23/36 ms
R1(config)#interface tunnel 21
R1(config-if)#ip address 192.168.1.1 255.255.255.0
R1(config-if)#ip mtu 1400
R1(config-if)#ip tcp adjust-mss 1360
R1(config-if)#tunnel source 1.1.1.1
R1(config-if)#tunnel destination 3.3.3.2
R1(config-if)#exit
R1(config)#end
R3(config)#interface tunnel 21
R3(config-if)#ip address 192.168.1.2 255.255.255.0
R3(config-if)#ip mtu 1400
R3(config-if)#ip tcp adjust-mss 1360
R3(config-if)#tunnel source 3.3.3.2
R3(config-if)#tunnel destination 1.1.1.1
R3(config-if)#exit
R3(config)#end
R1(config)#router eigrp 6123
R1(config-router)#network 192.168.1.0
R1(config-router)#network 10.0.0.0
R1(config-router)#no auto-summary
R1(config-router)#exit
R3(config)#router eigrp 6123
R3(config-router)#network 192.168.1.0
R3(config-router)#no auto-summary                                                           cy
R3(config-router)#network 30.0.0.0
R3(config-router)#exit
R1#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/28/32 ms
 R1#show ip interface brief | exclude ?
  LINE  Regular Expression
R1#show ip interface brief | exclude unass
Tunnel21               192.168.1.1     YES manual up                    up
R1#traceroute 30.1.1.1
Tracing the route to 30.1.1.1
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.1.2 56 msec 52 msec 20 msec
R1#traceroute 30.1.1.1 source 1.1.1.1
  1 192.168.1.2 24 msec 32 msec 24 msec
R1#traceroute 40.1.1.1
Tracing the route to 40.1.1.1
  1 1.1.1.2 16 msec 16 msec 20 msec
  2 4.4.4.2 16 msec 32 msec 40 msec
R1(config)#interface tunnel 41
R1(config-if)#ip address 192.168.40.1 255.255.255.0
R1(config-if)#tunnel destination 4.4.4.2
R1(config-if)#exit
R1(config)#end
R4(config)#interface tunnel 41
R4(config-if)#ip address 192.168.40.2 255.255.255.0
R4(config-if)#ip mtu 1400
R4(config-if)#ip tcp adjust-mss 1360
R4(config-if)#tunnel source 4.4.4.2
R4(config-if)#tunnel destination 1.1.1.1
R4(config-if)#end
R1(config-router)#network 192.168.40.0
R1(config)#end
R4(config)#router eigrp 6123
R4(config-router)#network 192.168.40.0
R4(config-router)#network 40.0.0.0
R4(config-router)#no auto-summary
R4(config-router)#end
*Feb 11 12:46:27.511: %SYS-5-CONFIG_I: Configured from console by console
  1 192.168.40.2 20 msec 52 msec 40 msec
R2#traceroute 40.1.1.1 source 20.1.1.1
  1 4.4.4.2 28 msec 28 msec 16 msec
R2#ping 30.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/16/20 ms
R2#ping 40.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/10/12 ms
R2#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/15/28 ms
