gregorypierce1
IS there a way to upgrade the ios on a cisco 9200l switch using a usb drive instead of using a tftp server? If so could someone point me to the article or tell me how this can be done? These switches seem to be more complicated than previous switches. Thanks for your time.
Answer
Cristian Matei
  You should be able to copy from usbflash0: to flash:
Cristian Matei.
gregorypierce1
After trying the commands with both usb ports I get the same result if I try to copy the file to flash. Flash is read only.
switch: copy usbflash1:/cat9k_lite_iosxe.16.12.03.SPA.bin flash:
Unsupported destination device/filesystem.
balaji.bandi
you are on switch: not on switch#
follow below thread to boot from USB, if not able to view USB follow next steps as per the thread :
https://community.cisco.com/t5/switching/catalyst-9200-ios-install/td-p/3926015
gregorypierce1
I should be able to copy as you said but it doesn't work as I said before. I've tried the copy mode mentioned from Rommon mode and from switch# mode as well with no working results as of yet.
As far as the link goes, he set his up to boot from a tftp server which isn't what i want to do. I can boot it from usb but I want to install the ios from the usb to the device flash: it just doesn't work like it use to. I will keep trying things and hope to find an answer.
Leo Laohoo
Post the complete output to the command "dir usbflash0:"
balaji.bandi
I suggest for now to check the USB recognized, some USB may have issue, so check is the USB mounted on Cisco device.
korykeenan
This is old but I had the same problem.
First, it takes a while for the USB to load, and the console never tells you.  Anyway first, you have to boot from the USB drive, then once it's running, flash: won't be RO anymore and you can perform the copy, then boot using the copied file.
boot usbflash0:/cat9k_example.bin
* wait for boot
copy usbflash0:/cat9K_example.bin flash:
balaji.bandi
what is the error you get here ? what is the output of dir flash: or dir
gregorypierce1
Got it figured out a while back, just forgot to update sorry. I was able to boot the switch using the drive and copy the file over at that point. Planning on going Meraki one day so I wont have to do this again.
R4Z0R84
If you've already got it running an ios there's not enough flash storage to copy then install the new ios, run the following:
#Installs directly from usb stick, from switch# prompt
install add file usbflash0:/cat9k_lite_iosxe.17.06.05.SPA.bin activate commit
#removes old versions, from switch# prompt after successful install this will clear out storage of previous ios.
install remove inactive
ensure you manually delete .bin file from flash: if you have already put it there, del flash:\cat9k_example.bin
this is mostly a reference for myself when I need to update again in the future but hope it helps someone else as well.
