Showing results forĀ
Search instead forĀ
Did you mean:Ā
On ND appliance I'm using SFP-10G-TX in VIC1455, is it supported?
WOLFGANG MEHLER
I've 3 ND physical appliances running. Mgmt and Data ports are connected to N9K-C93108-TC-FX3P leaf switches.
On the VIC1455 adapter I've SFP-10G-T-X installed to connected the appliances data ports to the ACI fabric.
My problem is that the Data ports are not coming up, so my question is are the SFP-10G-T-X transceivers are supported in Nexus Dashboard appliance (on VIC 1455 they are supported).
Problem fixed
Downgrade the firmware of the VIC1455 adapter on all 3 ND appliances from 4.2(3x) to 4.2(2a) because of this BUG: CSCwh06536
DominikPecak
Level 6
Level 6
The issue seems to be fixed in 4.3.2.230270.
