Swagger ui not available on Nexus Dashboard Orchestrator
pn2020
All Cisco ACI MSO REST API documentations mention that I can get into the swagger ui page, by logging into the orchestrator page, and then use this URL: <mso-ip>/docs/userdocs#/
Yet, after logging into the orchestrator, I got an "404 not found'" nginx error.  There is no option on the upper right corner to go to the swagger ui page, within the orchestrator tool.  Do we have to configure anything within orchestrator to see the swagger ui page?
Peter
https://www.cisco.com/c/en/us/td/docs/dcn/mso/3x/api/cisco-aci-multi-site-rest-api-configuration-guide-301/m_using_rest_apis.html#id_93639
qsnyder
Let me verify this.  I assume you're using the new NDO sandbox?  If so -- I have heard from the BE that there are some quirks with 4.0(2i), which is the version of NDO running on that sandbox.  I'll verify whether or not this is indeed the case.
Thanks @qsnyder for a quick response.
Not sure what you mean by sandbox, but it's for lab.  These are the versions.
qsnyder
I don't have access to a 3.7 NDO -- but in the 4.0(2i) version running in our DevNet Sandbox (devnetsandbox.cisco.com) -- I was able to access the API docs through: https://<ND IP>/apidocs and then selecting "Nexus Dashboard Orchestrator" from the drop-down menu (click on where it says "Nexus Dashboard" with a downward facing carat next to it.
You can also get there through clicking Help > Help Center > API Docs on any screen in ND/NDO.
Hope that helps!
q.
