DCNM to Nexus Dashboard
michael18
Installing a single node ND to replicate what DCNM gave us. DCNM was used to monitor nexus switches. During ND cluster bring up I have Fabric Controller or Orchestrator options. Neither seem to fit monitoring of the environment. Which is the best option to use?
Robert Burns
Hi  Michael,
"Fabric Controller" (aka NDFC) is the evolution of DCNM.  It's pretty much the same product with a newer name, and additional functionality.   There's a guide on migrating your existing DCNM instance to NDFC here: https://www.cisco.com/c/en/us/td/docs/dcn/nd/3x/deployment/cisco-nexus-dashboard-and-services-deployment-guide-311/nd-upgrade-dcnm.html
Robert
Robert Burns
Hi  Michael,
Robert
M02@rt37
Hello @michael18
Cisco NDFC (former DCNM) runs as an application on Cisco Nexus Dashboard (ND).
ND is a single launch point to monitor and scale across different sites, whether it is Cisco ACI fabric controllers, the Cisco APIC, or Cisco Nexus NDFC.
DCNM to NDFC Migration:
Best regards
michael18
Thanks for your responses. I have tried that guide but decided to install rather than upgrade. Ive got very little experience with python.
I got to the point where I needed to choose a persona. I chose what I thought would replicate DCNM, the SAN controller but im not sure that gives me what I need. I'll try again soon.
