moving from DCNM to Nexus dashboard
michael18
Im trying to deploy the Nexus Dashboard using ova.
what subnet is required for the management address subnet. how many IPs does it require. the document suggests quite a large subnet. Is that required and is it routable over the network or is it just used in the internally in the dashboard?
Document. step 11
https://www.cisco.com/c/en/us/td/docs/dcn/nd/3x/deployment/cisco-nexus-dashboard-and-services-deployment-guide-311/nd-deploy-esx-31x.html
M02@rt37
Hello @michael18
IP MGMT convered in step 11 is the IP used for GUI access.
Use your management subnet (or other). In the example the subnet used is a /21. The first IP of the subnet is the Gateway and one IP of that subnet is configured as mgmt IP.
Best regards
M02@rt37
Hello @michael18
Best regards
Thanks M02@rt37
Got it! Im entering a single IP for management from a subnet with mask in / format. And the gateway as single IP. I understand now.
