N9K-C9348GC-FX3 Breakout Cable Compatibility with NDFC
mushtaq-elhajaj
Hi everyone,
I am currently designing a network for a customer using N9K-C9348GC-FX3 switches. These switches have a limitation with 10G ports, as they come with:
4 × 1/10/25 Gbps SFP28 ports
2 × 40/100 Gbps QSFP28 ports
The customer requires 6 × 10G ports, so we are considering using breakout cables to achieve the necessary port capacity. However, I have never used breakout cables with NDFC, and my assumption is that it should work.
Has anyone used breakout cables on these switches with NDFC, or is there any known issue that we might encounter?
Appreciate any insights or experiences you can share.
0 Replies 0
