NDFC Deploy Issues
kmelchior
Level 2
Level 2
I am new to NDFC. I have my fabric built and switches discovered. I am trying to do the configuration but no matter what I am configuring I cannot 'deploy' the config. It is just not an option, more or less 'greyed out'. I can 'recalculate' after making any changes but on the next screen 'deploy all' is greyed out. Any suggestions would be appreciated.
Thanks!
dodgerfan78
Level 5
Level 5
Did you fix this? Mine are stuck in Migration mode and nothing will change them.
CSCO12101118
Community Member
If a VPC pair is not selected after seeding the switch then, switches will be stuck in Migration mode
