01-21-2024 01:42 PM
I'm trying to download the NDFC Cisco-ndfc-12.1.2e.nap on Nexus Dashboard 9.2.3.1c.
I downloaded the NDFC on my laptop and then i'm trying to upload it on ND adopting the option for location as "local".
Unfortunately, once i finshed to donwload on ND the SW, this is the message i get and it doesn't allow me to end the whole process.
Do you have any ideas which could be the reason?
thanks 1000
Mario
Solved! Go to Solution.
03-11-2024 10:12 PM
try to clear the cookies or use different web browser, check if its help
03-11-2024 10:12 PM
