05-04-2023 02:20 AM
Hi All,
Anyone had tried Nexus Dashboard 2.2(2d) with Nexus Dashboard Orchestrator 4.0(2i) on DevNet Sandbox and than push configuration such as EPG, BD and VRF from NDO to APIC.
I tried and always got error "Template Deployment Failed - code: "182", text: "SiteId is not configured in FabricExtConnP."". for EPG, BD and VRF.
I could push config such tenant and application profile without issue.
Please share your though, I want to know whether this virtual appliance is reliable to test configuration and test Ansible script.
Solved! Go to Solution.
05-15-2023 09:45 PM
Thanks for the question.
The error it self, should be some configuration issues of the infra (APIC/NDO), and generally we will try some commands/methods for troubleshooting the issue. Like:
And for DevNet Sandbox environment, it would be good approach to contact lab env support team, and you could have contact them by submitting a conversation - just like this one - at below portal.
Hope you can find proper one and get the issue resolved ASAP.
BTW, If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco Nexus Dashboard through our live Ask the Experts (ATXs) session. Check out this ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Thanks.
05-15-2023 09:45 PM
Thanks.
