12-07-2021 04:54 AM
Any idea why a Nexus 93180YC-FX switch would stop showing any syslogs even when entering "show logging"?
We already tried 'clear logging logfile' with no difference.
Version is 7.0(3)I7(10)
Solved! Go to Solution.
12-07-2021 01:15 PM
Hi @RahmaSallm
You can use the command "show system internal flash" to check the /var/log/ directory and ensure that space is available for that directory. If the directory is 100% then you will have to clear some space (you could check with TAC on what and how to).
Stay safe,
Sergiu
12-07-2021 05:10 AM
have you configured syslog information - post show run | in logging
12-07-2021 01:15 PM
Hi @RahmaSallm
Stay safe,
Sergiu
12-08-2021 12:24 AM
You are right.
I see that it is full:
13:44:47.182#none 51200 51200 0 100% /var/volatile/log
but to see the contents of it would the command be:
show system internal flash dir /var/volatile/log/
or
show system internal flash dir /var/volatile/log/external/
I've been googling that but all I can find is
show system internal flash dir /var/log/external/
