01-24-2025 02:01 AM
During "Recalculate and Deploy" phase after adding switches, I received so many errors for a brownfield deployment which I fixed some of them such as requiring the name UNDERLAY for ospf underlay process and forcing BGP to use private AS numbers but this last one I cannot figure out how to fix:
Switch [S21/9QY3LABZABO]: Underlay is V4. Fabric interface [Ethernet1/1]: Required [p2p] interface configuration not found.
Switch [S21/9QY3LABZABO]: Underlay is V4. Fabric interface [Ethernet1/2]: Required [p2p] interface configuration not found.
Switch [L11/95VDWK8PX55]: Underlay is V4. Fabric interface [Ethernet1/1]: Required [p2p] interface configuration not found.
Switch [L12/91OQSL0QLRK]: Underlay is V4. Fabric interface [Ethernet1/2]: Required [p2p] interface configuration not found.
Switches are still in migration mode. Please resolve all errors and retry Recalculate & Deploy.
My interfaces have this config:
interface Ethernet1/1
mtu 9216
medium p2p
no ip redirects
ip unnumbered loopback0
no ipv6 redirects
ip ospf network point-to-point
ip router ospf UNDERLAY area 0.0.0.0
ip pim sparse-mode
no shutdown
interface loopback0
ip address 1.1.1.21/32
ip pim sparse-mode
Could you tell me what config I should have under this interface and others in my fabric to fix this problem? I very much appreciate your help.
01-24-2025 09:42 AM
I have not noticed that error depends on your network and what version of NDFC, are you configuring using Cli or template ?
check below guide :
01-24-2025 10:53 PM - edited 01-24-2025 10:54 PM
Thank you Balaj for the reply. Like I said this is a brownfield deployment and I am connected to devices (virtual devices in my lab) using out-of-band management network.
When adding the switches I decided to keep the configuration intact but in the process of first deployment, it seems that NDFC tries to match the current configuration with it's templates.
Now, with this error, I am not sure what config I should add to the interfaces to fulfill the requirement. It would be nice if you provide a complete standard configuration for a fabric interface in a VXLAN environment.
My guess is NDFC looks for loopback 1 instead of loopback 0 I have used for ip unnumbered command, otherwise I will change the config and give interfaces unique IPs/30. I want to check it on Monday
