Tetration - ERSPAN/Netflow Virtual Appliance Deployment
muneeb.ali07
Beginner
Beginner
Greetings,
      I have deployed and configured the ERPSAN VA and Netflow VA as per documentation in TECDCN-2601 and https://www.cisco.com/c/dam/en/us/td/docs/data-center-analytics/tetration-analytics/sw/install/cta_install_guide_for_sensor_agents.pdf
my ip_config is below
172.16.189.174/24 172.16.189.254
172.16.189.175/24 172.16.189.254
172.16.189.176/24 172.16.189.254
After mounting the .iso file in both Netflow VA and ERSPAN VA. I rebooted the VM.
However, in the web console of VM i can't see the anticipated output of docker ps. In my result there are no containers however, service tet-span-sensors and tet-nic-driver are active.
Please advise.
muneeb.ali07
Beginner
Beginner
Ok I have figured it out.
Two things I missed or mis-configured.
First, both appliances run docker behind the scenes. So I needed to enable virtualization for the particular VM in vSphere.
Second, when I created the iso file. I renamed .rpm to something else like tet-sensor.X.X.X.rpm to tet-netflow.rpm. When scripts are executed under /usr/local/tet/sensor_containers_setup.sh I had to rename the tet-sensor.?.?.?*.rpm to tet-*.rpm.
I reboot the VM while the ISO still connected and it worked.
muneeb.ali07
Beginner
Beginner
Recognize Your Peers
