09-07-2023 11:15 PM
When Trying to onboard the cisco DNAC in cisco nexus dashboard. The virtual networks are not getting discovered.
What are the troubleshooting steps?
11-15-2023 11:51 PM
Hi @prohit,
Thanks for raising your question in Nexus Dashboard Community. For DNAC with Nexus Dashboard integration, you can refer to below doc link. And Cisco Nexus Dashboard and Cisco DNAC integration allows for automation of a subset of network connectivity and macro segmentation scenarios across Nexus and campus SD-Access fabric deployments. This integration is under limited availability.
You can try to use Nexus Dashboard Orchestrator (NDO) adds support for Cisco SD-Access and Cisco ACI integration. Meanwhile, you should Configuring Connectivity Toward the SD-Access Domain. (Checking below this guide)
11-16-2023 01:06 AM
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco Nexus Dashboard through our live Ask the Experts (ATXs) session. Check out this ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
