Some Questions about Licensing on Nexus 9336-FX2
Peyman Zadmehr
Hi Everybody
I am searching about Licensing on Nexus 9336-FX2.
I have a scenario which I do not need any fancy features on this switch. Features like (ACI,DCNM,Routing,...) I just want to use this switch as a Layer-2 Device with 100GE ports and Doing stuffs like LACP and QinQ and VLAN-Tagged traffic.
What I understood from information provided  in following link I don't need any license for these features If I want to use the switch as a pure layer-2 device(Actually it will be used in Core network not a DataCenter)
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html
Is this assumption correct?
Thank you for your help and guidance....
Peyman
Sergiu.Daniluk
Hi @Peyman Zadmehr
First of all, from perspective of functionality, Nexus 9000 (and Nexus 3000) switches family are using something which is called "honor-based licensing". This means that whatever feature you enable on the switch, it will work, regardless if you have or not the required license installed. If you do not have the license, you will get a message like this:  WARNING: 'LAN_ENTERPRISE_SERVICES_PKG' LICENSE NOT FOUND ON THE SYSTEM !!!!!!. You have tried to enable a licensed feature [ospf] without installing the 'LAN_ENTERPRISE_SERVICES_PKG' license, which has not been found on the system
Now coming back to your question, do you need a license if you want to use the switch only for L2 switching, q-in-q and LACP?
If the switch is for testing or not production traffic, then no.
If the switch is in production, then yes. You will need it because this also will give you support from TAC. You can simply go for essentials which includes all the basic features (routing and switching).
It is mandatory to have the license? well not quite... but be cautious of this caveat: if you encounter any issues, support might be limited.
Cheers,
Sergiu
Peyman Zadmehr
Dear All
Is there anyone who can help me in this regard?
Thank you
Sergiu.Daniluk
Hi @Peyman Zadmehr
Cheers,
Sergiu
Dear Sergiu
Thank you for your answer..
