Block access to config mode - nacm rule
suvdeshm
What is the nacm rule to block access to config mode but be able to read device config and do sync-from for all users?
When I try config mode I can get in but I cannot actually configure anything on device but what is a way to not allow to get in config mode as well?
The outcome for me:---
oper@ncs(config)# devices device ios0 config exec a
Possible completions:
  a
  admin-mode     Set to run the action in admin mode
  auto-prompts   One-shot auto-prompts list, used to ignore/reply on questions
oper@ncs(config)# exit
This is the nacm rule that I have currently :------
admin@ncs# show running-config nacm
nacm write-default deny
nacm cmd-read-default permit
nacm cmd-exec-default permit
nacm rule-list oper
group [ oper ]
rule devices-config-rule
  path              /devices/device/config
  access-operations read
  action            permit
tohagber
The cmdrule would be something like this:
admin@ncs# show running-config nacm rule-list oper
nacm rule-list oper
group [ oper ]
cmdrule config_mode1
context * ! *
command config ! *
access-operations * ! *
action deny
cmdrule config_mode2
context * ! *
command configure ! *
action deny
tohagber
To block groups to get into config mode you can use cmdrule to reject the "config"/"configure" command token. cmdrule is a NSO proprietary cli authorization added to nacm see cmdrule here.
tohagber
nacm rule-list oper
group [ oper ]
context * ! *
command config ! *
action deny
context * ! *
action deny
Thank you ! That worked.
