02-07-2022 09:01 PM - edited 02-07-2022 09:02 PM
G'day 🙂
I'm in the process of developing a HLD for a potential NSO deployment. While reading the LSA documentation on the Developer website, I came across the terms CFS and RFS. From what I understand:
- The upper layer (CFS) is customer-facing and can provide northbound connectivity for external programs and processes. Along with this, it manages the communications from an external source and pushes the required changes down to the relevant RFS nodes.
- The lower layer (RFS) is resource-facing and manages the configuration for attached devices.
Two things I would like clarified are:
1) Is my understanding of the CFS and RFS correct? If not, where can I find more information as I can't see too much in the existing documentation.
2) Since the RFS manages configuration for each connected device, does the CDB on the CFS maintain the configuration from all RFS's?
I'm still quite new to NSO and really enjoying the work I'm doing at the moment. I'll be looking at doing some formal NSO training later on in the year to recertify my CCNP Enterprise certification.
Thank you, and I look forward to learning more and contributing to the NSO community.
Solved! Go to Solution.
02-07-2022 09:54 PM
02-07-2022 09:54 PM
02-07-2022 10:05 PM
G'day @vleijon,
Thank you for your reply.
It's good to know that my understanding of the CFS/RFS concepts is correct. Once I get my NSO instances going again, I will check out the example and go from there.
