Control DI/DO status from CISCO IE4000
pawhan11
I am looking for a way to read DI status of alarm signal connected to IE4000 module and to controll DO state of alarm relay.
In our test case we need to verify electric wiring and read correct inputs/write correct outputs with CISCO switch.
Is there a way to read this directly with simple set of commands, without necessity to create alarms?
Thanks in advance!
vleijon
This is the Cisco NSO forum, you will probably have a more luck in a forum more dedicated to the IE4000, maybe https://community.cisco.com/t5/switching/bd-p/6016-discussions-lan-switching-routing?
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
