create a key value pair in python maagic
peter.z.larsson
Level 2
Level 2
I can't figure out how to create a key value pair via python maagic api.
I have an ciso ios-xr device and want to add a community-set. Like this:
community-set CS-CORE_REGION_ID-LOCAL
  39651:1099
end-set
I have the community-set defined in ncs but without any value:
admin@ncs% show devices device sth0-ser0 config cisco-ios-xr:community-set CS-CORE_REGION_ID-LOCAL | display json
  "data": {
    "tailf-ncs:devices": {
      "device": [
          "name": "sth0-ser0",
          "config": {
            "tailf-ned-cisco-ios-xr:community-set": [
                "name": "CS-CORE_REGION_ID-LOCAL"
[ok][2017-10-19 18:02:39]
I can create a new key "set" by:
                for cs in root.devices.device[bng_id[0]["name"]].config.cisco_ios_xr__community_set:
                    if cs.name == "CS-CORE_REGION_ID-LOCAL":
                        rt_val = "39651:" + bng_id[0]["region_cs"]
                        cs.set.create
                        cs.set["value"].create
                        cs.set.value = rt_val
                        print(cs.set)
I get te following output error when running the script:
Traceback (most recent call last):
  File "import-sp-data-itux-bng-ver1.py", line 153, in <module>
    main()
  File "import-sp-data-itux-bng-ver1.py", line 149, in main
    set_sp_id(bng_id)
  File "import-sp-data-itux-bng-ver1.py", line 75, in set_sp_id
  File "/home/peter/ncs-4.4.2/src/ncs/pyapi/ncs/maagic.py", line 1037, in __getitem__
    raise KeyError('%s not in %s' % (keystr, self._path))
KeyError: '{value} not in /ncs:devices/device{sth0-ser0}/config/cisco-ios-xr:community-set{CS-CORE_REGION_ID-LOCAL}/set'
Any idea what needs to be changed?
Thanks Fredrik, you guided me in the correct direction.
s = cs.set.create(rt_val)
Did the work.
frjansso
Not sure about the YANG model here, but I have two ideas:
- OR -
s = cs.set.create()
s.value = rt_val
Did the work.
