Python Data Provider Example
Does anyone have example of a working data provider package leveraging python for an example? The Docs directory has a Java exmaple, but curious if anyone has a walk through or package example in python they could share.
Interested in this capability for external services like ServiceNow, or an IPAM system.
Brandon
frjansso
Really a toy example, but might send you off in the right direction. Please change confd for ncs in the imports.
YANG:
  container interface {
    list GigabitEthernet {
      key "name";
      leaf name {
        type string;
      leaf shutdown {
        type empty;
      container stats {
        config false;
        tailf:callpoint "stats";
        leaf sent {
          type uint32;
        leaf received {
          type uint32;
    import logging
    import random
    from confd.experimental import DataCallbacks
    from _confd.dp import register_data_cb
  class Handler(object):
    def __init__(self, log):
        self.log = log
    def get_object(self, tctx, kp, args):
        recv = random.randint(0, 10000)
        sent = random.randint(0, 10000)
        return {
            'stats': {
                'received': recv,
                'sent': sent
    def get_next(self, tctx, kp, args, next):
        self.log.info('get_next: ' + str(kp))
        return None
    def count(self):
        self.log.info('count: ')
        print('count')
        return 0
  def start(daemon):
    log = logging.getLogger(__name__)
    dp = DataCallbacks(log)
    dp.register('/config:interface/config:GigabitEthernet', Handler(log))
    register_data_cb(daemon.ctx(), 'stats', dp)
Thanks Fredrik!
Apologies for my ignorance, how would I structure this as a package inside NSO?
For example to beign would I leverage:
ncs-make-package --service-skeleton python test_dp  --component-class NAME (default main.Main)
then remove the service references in YANG?
I'll experiment and try! But wanted to double check.
Thanks again,
Brandon
Yes, that's the way I'd do it!
