deref() doesn't work
prmalik
Hi Team,
I have below error with the deref(). I also looked at Xpath and some old discussions but not able to figure out the issue.
      leaf sitename-existing {
        tailf:info "Unique Existing Site Name";
        description "This leaf for existing sitename. This is needed to pull site UUID ";
        type leafref {
        path "deref(../../device)/../ncs:config/vts-service:vts-service/vts-service:sites/vts-service:site/vts-service:id";
Error :
vtsInstance-site-router.yang:41: error: vtsInstance-site-router:device in the path for sitename-existing at vtsInstance-site-router.yang:37 is not found
Below are details (Xpath for reference)
/devices/device[name='MPN-DEV0']/config/vts-service:vts-service/sites/site[id='be416d94-a2c2-41a4-b186-aec1739413ff']/name SITE3
Can you pls help me to understand what's wrong here ?
hniska
As the error message says, in your YANG module vtsInstance-site-router, two steps up from the deref(), no leaf named device can be found. So check the path, to many, to few ../ ?
hniska
Hi Hakan,
Thanks for your reply. I tried all combinations, after fixing device, I get below error :
error: vts-service:vts-service in the path for sitename-existing at vtsInstance-site-router.yang:45 is not found
for testing, I have configured as following :
(Below path is not working)
path "/ncs:devices/ncs:device[ncs:name=current()/../device]/ncs:config/vts-service:vts-service/vts-service:sites/vts-service:site/vts-service:id";
I have similar path working fine for XR (below path is working fine)
path "/ncs:devices/ncs:device[ncs:name=current()/../../device]/ncs:config/cisco-ios-xr:interface/cisco-ios-xr:GigabitEthernet/cisco-ios-xr:id";
I am still not sure issue with the vts-service as I see below xpath on NSO
admin@ncs# show running-config devices device MPN-DEV0 config | display xpath
Do you know why its complaining about  vts-service ? or something I have still wrong in the path ?
prmalik
This has been solved. Pyang was reporting error but there was no issue with the compilation.
Thanks !!!
