Disable TLSv1.0 in NSO
Shantha Kumar Selvaraj
Hi All,
Is there a way to disable TLSv1.0 in NSO and are here any implications of doing this,Couldn't find setting in ncs.conf,We are hitting Qualys QID 38628(SSL/TLS Server supports TLSv1.0) which is vulnerable.
Akira Iwamoto
Check manual for ncs.conf.
       /ncs-config/webui/transport/ssl/protocols (string) [DEFAULT]
           Specifies the SSL/TLS protocol versions to be used by the server
           as a whitespace-separated list from the set sslv3 tlsv1 tlsv1.1
           tlsv1.2, or the word "DEFAULT" (use all supported protocol
           versions except sslv3).
To remove sslv3 and tlsv1, the below config would do it.
add <protocols>
  <webui>
    <transport>
      <ssl>
        <protocols>tlsv1.1 tlsv1.2</protocols>
      </ssl>
    </transport>
</webui>
Akira Iwamoto
add <protocols>
  <webui>
    <transport>
      <ssl>
      </ssl>
    </transport>
</webui>
