Facing issue with service model with LIST construct
kbarve
I am using CISCO ISO NED and trying to build a service model for 802.1x access policy configuration
Facing issue with "radius r1 server-ip 1.1.1.1 secret 111 auth-port 1 ".
In yang model i have defined radius as a list
list radius {
    tailf:cli-suppress-mode;
    leaf server-name {
      tailf:info "Specify name for radius server";
      mandatory true;
      type string;
    leaf server-ip {
       tailf:info "Specify a RADIUS server <Hostname or A.B.C.D>";
       mandatory true;
       type inet:ipv4-address {
         pattern "[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+";
    leaf auth-port {
       tailf:info "Specify UDP port for RADIUS authentication server";
       mandatory true;
       type uint16;
    leaf secret {
       tailf:info "Specify encryption key for Radius Server";
       mandatory true;
       type string;
Issue is: multiple entries of radius server do get created but the values that i pass for the leaves are getting appended.  Show below in the output.
admin@ncs(config)# services switch-access-policy s2 radius-source-interface-type FastEthernet radius-source-interface-name 0/1 device SWITCH-0
admin@ncs(config-switch-access-policy-s2)# radius r1 server-ip 1.1.1.1 secret 111 auth-port 1
admin@ncs(config-switch-access-policy-s2)# radius r2 server-ip 2.2.2.2 secret 112 auth-port 2
admin@ncs(config-switch-access-policy-s2)# commit dry-run outformat native
native {
    device {
        name SWITCH-0
        data aaa new-model
             aaa authentication dot1x default group radius
             aaa authorization network default group radius
             ip radius source-interface FastEthernet0/1
             dot1x system-auth-control
             radius server r1
              address ipv4 1.1.1.12.2.2.2 auth-port 12
              key 111112
             radius server r2
              key 111112
Can someone plz let me know the solution?
lmanor
Agree'd, strange behavior...
One thing that I did notice is that your list does not have a 'key' statement. Is this intended?
If this is a config list I believe a 'key' statement is needed:
list radius {
    key "server-name";
    leaf server-name {
      mandatory true;
      type string;
