NSO Design
Ivan Sanchez
Hi, I am trying to find information about how to design a NSO solution in order to try to figure out this questions that one of my clients ask me.
  • How many services and devices can support with just one NSO box.
  • How should be the migration from legacy networks to NSO solution.
  • In a Service Provider environment, in which part of the network should be installed the NSO
Thanks.
alam.bilal
There is a sizing guide which gives a starting point. NSO stores the configs for all devices and service instances in the in-memory database (CDB). So an assessment needs to be made of the current size of the device+service configs and also the projected growth. Add some buffer for metadata (backpointers, refcounts etc).
With regards to request throughput, almost always commit-queues need to be used to scale. Some simulations that were done, a rate of 10-15 requests per second seems to be very possible with a single NSO node. Obviously depends on the CPU specs.
NSO will "sync-from" the device configuration out of the box. In terms of service activation, an incremental approach is preferred. Take a greenfield service/use-case if possible. Otherwise pick some high value high frequency use-case[s] and start there. Migration of all brownfield service instances (a.k.a. service reconciliation) can be a very tedious and expensive. Depends on the current processes that were used to provision the services in the first place. Number of variations etc
No hard and fast rule here. NSO can be installed on bare-metal or in a VM form-factor. The Linux server it runs on needs to be locked down (system install - admin guide) and NSO needs to have connectivity/access to all the devices that it needs to  manage.
alam.bilal
