Get the value of IP address on device interface using python maapi
nso20
Level 3
Level 3
I can get the value of description on device interface using python maapi as below, but I couldnot get the value of ip address:
import ncs
import ncs.maagic as maagic
import ncs.maapi as maapi
with ncs.maapi.single_read_trans('admin', 'system', db=ncs.OPERATIONAL) as m:
    root = ncs.maagic.get_root(m)
    print(root.devices.device['mydevice'].config.ios__interface.GigabitEthernet[1].description)
my_interface_desc
    print(root.devices.device['mydevice'].config.ios__interface.GigabitEthernet[1].ip.address)
the value returned is the word address not the ip address itself.
device: cisco IOS XE
NSO: 4.7.5
lmanor
Right, you need to look at how the interface address is modeled:
This is what I see on 5.3.2.1 with IOS ned v 6.46:
admin@ncs% show devices device ios-0 config interface GigabitEthernet 0/0 | display xml
<config xmlns="http://tail-f.com/ns/config/1.0">
  <devices xmlns="http://tail-f.com/ns/ncs">
    <device>
      <name>ios-0</name>
      <config>
        <interface xmlns="urn:ios">
          <GigabitEthernet>
            <name>0/0</name>
            <description>Test interface</description>
            <ip>
              <address>
                <primary>
                  <address>10.0.1.0</address>
                  <mask>255.255.255.0</mask>
                </primary>
              </address>
            </ip>
          </GigabitEthernet>
        </interface>
      </config>
    </device>
  </devices>
</config>
So you'll need to add in 'ip.address.primary.address' to get address:
In [12]: with ncs.maapi.Maapi() as m:
    ...:   with ncs.maapi.Session(m, 'admin', 'system'):
    ...:     with m.start_write_trans() as t:
    ...:         root = ncs.maagic.get_root(t)
    ...:         dev = root.ncs__devices.device['ios-0']
    ...:         devname = dev.name
    ...:         print (devname)
    ...:         desc = root.ncs__devices.device['ios-0'].config.ios__interface.GigabitEthernet['0/0'].description
    ...:         print (desc)
    ...:         addr = desc = root.ncs__devices.device['ios-0'].config.ios__interface.GigabitEthernet['0/0'].ip.address.primary.address
    ...:         print (addr)
    ...:         mask = desc = root.ncs__devices.device['ios-0'].config.ios__interface.GigabitEthernet['0/0'].ip.address.primary.mask
    ...:         print (mask)
ios-0
Test interface
10.0.1.0
255.255.255.0
lmanor
    <device>
      <name>ios-0</name>
      <config>
          <GigabitEthernet>
            <name>0/0</name>
            <ip>
              <address>
                <primary>
                </primary>
              </address>
            </ip>
          </GigabitEthernet>
        </interface>
      </config>
    </device>
  </devices>
</config>
    ...:         print (desc)
    ...:         print (addr)
    ...:         print (mask)
ios-0
Test interface
10.0.1.0
255.255.255.0
Thanks a lot, but why you use write_trans() instead of read_trans(), although we are reading values from CDB ?
lmanor
Sorry for the confusion on read/write (which is really read-write) transaction, I just grabbed an example that I had handy that likely wrote to the CDB as well as read.
The start_read_trans() should work equally as well if you are just reading from the CDB.
@lmanor
Many thanks for your quick response, last question, instead of getting a single value, can I get the output of whole configuration below the interface (e.g. description, ip address, ...) using python, something like:
root.ncs__devices.device['ios-0'].config.ios__interface.GigabitEthernet['0/0'].?
