Bookmark
Subscribe
1352
Getting operation failed in netconf for cisco 1941
raiuli
Dear all,
I have configured net conf in my Cisco1941 series and geting operation failed for  all the request i am sending through ssh
Here is the configuration
Current configuration : 1580 bytes
! Last configuration change at 08:56:09 UTC Wed Mar 13 2019
version 15.4
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
memory-size iomem 5
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1941/K9 sn FGL152923AY
username cisco password 0 passw0rd
redundancy
ip ssh rsa keypair-name sshkeys
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
netconf max-sessions 5
netconf lock-time 60
netconf max-message 2345
end
Following is the output of ssh communication with the cisco router
ssh -s cisco@192.168.0.1 netconf
Password:
<?xml version="1.0" encoding="UTF-8"?><hello><capabilities><capability>urn:ietf:params:netconf:base:1.0</capability><capability>urn:ietf:params:netconf:capability:writeable-running:1.0</capability><capability>urn:ietf:params:netconf:capability:startup:1.0</capability><capability>urn:ietf:params:netconf:capability:url:1.0</capability><capability>urn:cisco:params:netconf:capability:pi-data-model:1.0</capability><capability>urn:cisco:params:netconf:capability:notification:1.0</capability></capabilities><session-id>734691320</session-id></hello>]]>]]>
<?xml version=”1.0" encoding=”UTF-8"?><hello><capabilities><capability>urn:ietf:params:netconf:base:1.0</capability></capabilities></hello>]]>]]>
<?xml version="1.0"?>
<rpc message-id="101"  xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
       <get-config>
         <source>
           <running/>
         </source>
         </get-config>
     </rpc>]]>]]>
<?xml version="1.0" encoding="UTF-8"?><rpc-reply message-id="101" xmlns="urn:ietf:params:netconf:base:1.0"><rpc-error><error-type>protocol</error-type><error-tag>operation-failed</error-tag><error-severity>error</error-severity></rpc-error></rpc-reply>]]>]]>
aaa authorization exec default local
joepak
Hi, can you enable device trace in raw format and recreate the issue and see what the .trace file says? The info provided is not enough to understand why the operation is failing. Preferably you could tail -f /var/log/ncs and see what logs are affected when you recreate the issue and share the errors.
