Getting "Device does not have a Network Element Driver registered" on connect
ron.whitt
I'm getting "info Device N9Kv-1 does not have a Network Element Driver registered" when I try to connect vNexus device.
I had previously loaded the the cisco-nx 5.0 NED and it worked with the attached Nexus device.  However, I loaded the cisco-iosxr NED (6.0.1) and I got errors on package reload from the cisco-nx.  So I upgraded the cisco-nx to 5.2. This solved the package reload problem, but now I cannot connect to the nexus box.  I get the "does not have Network Element Driver registered" message when I try. I have tried deleting and re-adding the device and doing an ncs --with-package-reload.  Still getting the error message when I try to connect to the device.  Thanks.
See this warning in CHANGES of cisco-iosxr.
  WARNING:
    When using cisco-iosxr with other NEDs, certain combinations of NED versions
    may cause 'random' Exceptions. The reason for this is the introduction of
    a new common NED component - nedcom.jar - which initially was located in
    shared-jar, but later moved to private-jar. However, since the JAVA loader
    looks in shared-jar directories first, a newer NED with nedcom.jar in
    private-jar will still load another NED's older nedcom.jar in shared-jar;
    causing a version conflict and quite possibly an Exception.
    Hence, if you are using a newer NED (with private-jar/nedcom.jar) you must
    make sure no other NEDs in your project has a shared-jar/nedcom.jar. If they
    do, you must upgrade them to a version which also has nedcom in private-jar.
    The following NED versions have their nedcom.jar in shared-jar:
    a10-acos      3.6.5
    alu-sr        6.0.2 to 6.1.1
    cisco-asa     5.2 to to 5.2.1
    cisco-ios     5.2.8 to 5.4.2
    cisco-iosxr   6.0 to 6.1
    cisco-nx      4.4.7 to 4.5.2
    huawei-vrp    4.2.6
    In short, avoid the above NED versions when using other NEDs.
frjansso
Is there any way you're short on memory? E.g. from running NSO in a container?
Does: "show packages package * oper-status" reveal anything interesting?
Any error in ncs-java-vm.log?
Here are some stats, I don't see a memory problem, but maybe you'll see something I'm not.
so here is oper-satus:
admin@ncs# show packages package oper-status
packages package cisco-ios
oper-status up
packages package cisco-iosxr
oper-status up
packages package cisco-nx
oper-status up
I thought it might be a memory thing too, so I removed one of the NEDs, same result.
here is a cat /proc/meminfo
atcadmin@NSO-POC3480:~/ncs-run$ cat /proc/meminfo
MemTotal:       24689752 kB
MemFree:        18465576 kB
MemAvailable:   22386388 kB
Buffers:          226992 kB
Cached:          3796648 kB
SwapCached:            0 kB
Active:          4070196 kB
Inactive:        1719852 kB
Active(anon):    1769420 kB
Inactive(anon):     8416 kB
Active(file):    2300776 kB
Inactive(file):  1711436 kB
Unevictable:        3660 kB
Mlocked:            3660 kB
SwapTotal:      25162748 kB
SwapFree:       25162748 kB
Dirty:                60 kB
Writeback:             0 kB
AnonPages:       1772116 kB
Mapped:            65784 kB
Shmem:              9004 kB
Slab:             311804 kB
SReclaimable:     279224 kB
SUnreclaim:        32580 kB
KernelStack:        4544 kB
PageTables:         7884 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:    37507624 kB
Committed_AS:    2874040 kB
VmallocTotal:   34359738367 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
HardwareCorrupted:     0 kB
AnonHugePages:   1658880 kB
CmaTotal:              0 kB
CmaFree:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
DirectMap4k:       88000 kB
DirectMap2M:    25077760 kB
Still troubleshooting, backed the cisco-nx NED back to 5.1, now getting the error I was before when loading the iosxr:
admin@ncs# show packages package package-version
             PACKAGE
NAME         VERSION
cisco-ios    5.9.2
cisco-iosxr  6.0.1
cisco-nx     5.1
reload-result {
    package cisco-nx
    result false
    info [LOAD_PACKAGE[com.tailf.packages.ned.nedcom.NedComCliBase.<init>(Z)V]]
Note: this error went away when I loaded the 5.2 nx NED.
I removed the cisco-iosxr 6.0.1 NED and now I'm able to connect and sync with the device.
So.... there appears to be a conflict with the cisco-iosxr NED (6.0.1) and versions of the cisco-nx NED, the exception being the cisco-nx 5.2 NED.  But I can't get the cisco-nx 5.2 NED to connect to a device.
  WARNING:
    a10-acos      3.6.5
    huawei-vrp    4.2.6
