having issues with imported module's nodes
kerim mohammed
Level 3
Level 3
I am seeing the following error when trying to compile. Can you point me what I am doing wrong? the associated YANG Model lines (37 & 50 ) are :
path "/ncs:devices/ncs:device[name = current()/../sourcedevice]/config/nx:interface/Ethernet/name";
path "/ncs:devices/ncs:device[name = current()/../peerdevicename]/config/nx:interface/Ethernet/name";
 the complete yang module is attached.
ok. it compiled successfully when i tried:
path "/ncs:devices/ncs:device[ncs:name = current()/../sourcedevice]/ncs:config/nx:interface/nx:Ethernet/nx:name";
the ncs:config is bugging me though. should have been nx:config. any suggestion?
hniska
try this
path "/ncs:devices/ncs:device[ncs:name = current()/../sourcedevice]/config/nx:interface/Ethernet/name";
thanks for the reply. I tried that (ncs:name). That seems to take care of the "name" node issue. But another node starts raising similar issue. I tried "nx:config" to no avail. currently the path exress. is :
