05-12-2021 07:39 AM
Is it possible to display the devices that belgons to two device-group in the same time. For exemple I have a device-group that contains [ dev-1 dev-2 dev-3 dev-4 dev-7] and another device-group that contains [ dev-1 dev-3 dev-4 dev-5 ]. When I configure my service I want to see only [ dev-1 dev-3 dev-4 ].
I tried to use tailf:non-strict-leafref extension but it always displays all the devices that belongs to the second device-group.
Solved! Go to Solution.
05-12-2021 08:34 AM
05-12-2021 08:34 AM
05-12-2021 10:49 AM
Thank you for your reply vleijon.
Could you please give an exemple of how I can use must statement to check if a device belongs to a device-group.
