02-17-2020 06:01 PM
In juniper NED we configured ae interfaces but we are not able to view ae10 interfaces under physical interfaces to bind with.
nsoadmin@ncs(config-config)# configuration interfaces interface xe-0/0/0 gigether-options ieee-802.3ad
we are able to view list of ae interfaces under configuration
interfaces {
interface ae10 {
description tryae;
vlan-tagging;
mtu 9192;
link-mode full-duplex;
encapsulation flexible-ethernet-services;
aggregated-ether-options {
load-balance {
per-packet;
link-speed 1g;
lacp {
active;
unit 100 {
description "juniper aggrigration";
encapsulation vlan-ccc;
vlan-id 100;
input-vlan-map {
swap;
vlan-id 200;
output-vlan-map {
swap;
Need help on configuring the aggregated ethernet in Juniper devices
Solved! Go to Solution.
02-25-2020 01:26 AM
admin@ncs(config)# devices device jun0 config junos:configuration interfaces interface xe-0/0/2 gigether-options ieee-802.3ad bundle ?
Description: Join an aggregated Ethernet interface
Possible completions:
<string>
Something like this?
02-25-2020 05:29 AM
02-25-2020 01:26 AM
<string>
02-25-2020 05:29 AM
