How to add aggregated ethernet in Juniper with following NED ncs-5.3.0.1-juniper-junos-4.5.20
kiran kotari
In juniper NED we configured ae interfaces but we are not able to view ae10 interfaces under physical interfaces to bind with.
nsoadmin@ncs(config-config)# configuration interfaces interface xe-0/0/0 gigether-options ieee-802.3ad
we are able to view list of ae interfaces under configuration
    interfaces {
        interface ae10 {
            description   tryae;
            vlan-tagging;
            mtu           9192;
            link-mode     full-duplex;
            encapsulation flexible-ethernet-services;
            aggregated-ether-options {
                load-balance {
                    per-packet;
                link-speed 1g;
                lacp {
                    active;
            unit 100 {
                description   "juniper aggrigration";
                encapsulation vlan-ccc;
                vlan-id       100;
                input-vlan-map {
                    swap;
                    vlan-id 200;
                output-vlan-map {
                    swap;
Need help on configuring the aggregated ethernet in Juniper devices
2 Accepted Solutions
uavsec001
admin@ncs(config)# devices device jun0 config junos:configuration interfaces interface xe-0/0/2 gigether-options ieee-802.3ad bundle ?
Description: Join an aggregated Ethernet interface
Possible completions:
<string>
Something like this?
Thanks, We have found the following case id "685370891" where it suggests to configure via “ieee-802.3ad bundle ae<id>”
uavsec001
<string>
