Kicker Variables
tsiemers1
Getting started with using kickers to run an action after a service has been created. How do you set one of the leaves from the service as a variable in the kicker?
Yang:
module postmod_test {
  namespace "http://example.com/postmod_test";
  prefix postmod_test;
  import ietf-inet-types {
    prefix inet;
  import tailf-common {
    prefix tailf;
  import tailf-ncs {
    prefix ncs;
  import tailf-kicker { prefix kicker; }
  description
    "Bla bla...";
  revision 2016-01-01 {
    description
      "Initial revision.";
  list postmod_test {
    description "This is an RFS skeleton service";
    key name;
    leaf name {
      tailf:info "Unique service id";
      tailf:cli-allow-range;
      type string;
    uses ncs:service-data;
    ncs:servicepoint postmod_test-servicepoint;
    leaf vlan {
      type uint16;
    container actions {
      tailf:action vlanCleaner {
        tailf:actionpoint CleanUpIpam;
        input {
          uses kicker:action-input-params;
        output {
Python
# -*- mode: python; python-indent: 4 -*-
import ncs
from ncs.application import Service
from ncs.dp import Action
# SERVICE CALLBACK EXAMPLE
class ServiceCallbacks(Service):
    @Service.create
    def cb_create(self, tctx, root, service, proplist):
        self.log.info('Service create(service=', service._path, ')')
# ACTIONS EXAMPLE
class CleanUpIpam(Action):
    @Action.action
    def cb_action(self, uinfo, name, kp, input, output, trans):
        self.log.info('action name: ', name)
        self.log.info('KICKER HAS BEEN KICKED')
        self.log.info(f'Action input: kicker-id: {input.kicker_id}, path: {input.path}, tid: {input.tid}')
        self.log.info(dir(input))
# COMPONENT THREAD THAT WILL BE STARTED BY NCS.
class Main(ncs.application.Application):
    def setup(self):
        self.log.info('Main RUNNING')
        self.register_service('postmod_test-servicepoint', ServiceCallbacks)
        self.register_action('CleanUpIpam', CleanUpIpam)
    def teardown(self):
        self.log.info('Main FINISHED')
Kicker
kickers data-kicker test3
 monitor     /postmod_test:postmod_test
 kick-node   postmod_test:actions
 action-name vlanCleaner
What I would like is to send the value of vlan into the kicker.
So from the service using the leaf vlan:
leaf vlan {
      type uint16;
Create a kicker like so:
variable VLAN value /vlan
Is this possible with a data-kicker? I see the example in the guide using $PATH but not sure how that relates to a service leaf.
gmuloche
essentially because your action is defined in the service itself the following would work:
class MyAction(Action):
      @Action.action
          self.log.info(kp)
          # get the actions container
          kicked_node = ncs.maagic.get_node(trans, kp)
          # get the VLAN
          self.log.info(f"Vlan for this service is: {kicked_node._parent.vlan}")
CLI:
admin@ncs(config-blah-test4)# test test4 vlan 7
admin@ncs(config-blah-test4)# commit | debug kicker
 2020-02-25T10:00:49.617 kicker: test at /test:test[blah:name='test4'] changed; invoking 'test-action'
Commit complete.
Logs:
<INFO> 25-Feb-2020::09:58:01.109 test ncs-dp-94343-test:main-1-th-171: - Service create(service=/test:test{test4})
<INFO> 25-Feb-2020::09:58:01.130 test ncs-dp-94343-test:main-2-usid-49-test-actionpoint: - action name: test-action
<INFO> 25-Feb-2020::09:58:01.131 test ncs-dp-94343-test:main-2-usid-49-test-actionpoint: - KICKER HAS BEEN KICKED
<INFO> 25-Feb-2020::09:58:01.131 test ncs-dp-94343-test:main-2-usid-49-test-actionpoint: - Action input: kicker-id: test, path: /test:test{test4}, tid: 179
<INFO> 25-Feb-2020::09:58:01.131 test ncs-dp-94343-test:main-2-usid-49-test-actionpoint: - /test:test{test4}/actions
<INFO> 25-Feb-2020::09:58:01.131 test ncs-dp-94343-test:main-2-usid-49-test-actionpoint: - Vlan for this service is: 7
I don't think you will need the kickers:action-input-params and probably the code can be made a bit nice but it should get you started
regards,
Guillaume
gmuloche
      @Action.action
          self.log.info(kp)
          # get the VLAN
CLI:
Commit complete.
Logs:
regards,
Guillaume
This is exactly what I was after. Thanks for help.
