How to create netsim devices using two different types of ned in one directory which should start and stop using single netsim command command?
chandans
I want to create two types netsim devices for example PE(Cisco-ios) and CE(cisco-iosxr) which should start and stop using single command??
yfherzog
Have a look at the ncs-netsim help below.
If you create the first device(s) using 'ncs-netsim create-network', you can  add additional device(s) of same or different types with 'ncs-netsim add-to-network' using the same command structure.
If you create the first device using 'ncs-netsim create-device' you can add additional device with the 'ncs-netsim add-device' command (again, same command structure as create-device).
Once you created the devices, netsim will start, stop, restart all devices on the netsim dir, unless you specify a device name.
Hope that helps,
Yftach
YFHERZOG-M-W1ZZ:logs yfherzog$ ncs-netsim --help
Usage ncs-netsim  [--dir <NetsimDir>]
                  create-network <NcsPackage> <NumDevices> <Prefix> |
                  create-device <NcsPackage> <DeviceName> |
                  add-to-network <NcsPackage> <NumDevices> <Prefix> |
                  add-device <NcsPackage> <DeviceName> |
                  delete-network                     |
                  [-a | --async]  start [devname]    |
                  [-a | --async ] stop [devname]     |
                  [-a | --async ] reset [devname]    |
                  [-a | --async ] restart [devname]  |
                  list                      |
                  is-alive [devname]        |
                  status [devname]          |
                  whichdir                  |
                  ncs-xml-init [devname]    |
                  ncs-xml-init-remote [devname] |
                  packages                  |
                  netconf-console devname [XpathFilter] |
                  [-w | --window] [cli | cli-c | cli-i] devname
See manpage for ncs-netsim for more info. NetsimDir is optional
and defaults to ./netsim, any netsim directory above in the path,
or $NETSIM_DIR if set.
yfherzog
Hope that helps,
Yftach
                  delete-network                     |
                  list                      |
                  status [devname]          |
                  whichdir                  |
                  packages                  |
gschudel
In addition to the details that Yftach provided, you might also wish to look in the ncs ./examples
directory to check the "Makefile" in most of the provided examples. In most of the "Makefile" files
provided with the examples, a part of the recipes is (typically) to create and start NETSIM devices.
If you want you can even create your own - leading the the result you asked for (i assume) -- i.e. one command to start
both cisco-ios and cisco-ios-xr NETSIM devices..
For example, this recipe here (below) is a complete example. Save it as "Makefile"...
and then (after sourcing ncsrc), just type things like: "make clean all start" or "make demo-restart"
(please read and understand the Makefile contents, please read Makefile "man page")
# List the NED packages required for this project
NED_PACKAGES = \
cisco-ios \
cisco-iosxr
ALL_PACKAGES = $(NED_PACKAGES)
# Create the netsim using the create-network argument to ncs-netsim
NETWORK = create-network packages/cisco-ios 2 c \
create-network packages/cisco-iosxr 2 xr
NETSIM_DIR = netsim
MKDIR_P = mkdir -p
all: build-all $(NETSIM_DIR)
build-all:
for i in $(ALL_PACKAGES); do \
echo $${i}; \
   $(MAKE) -C packages/$${i}/src all || exit 1; \
   done
$(NETSIM_DIR):
${MKDIR_P} ncs-cdb logs state
ncs-netsim --dir netsim $(NETWORK)
ncs-netsim ncs-xml-init > ncs-cdb/netsim_devices_init.xml
# --------STOP/START code...
# stop everything...
stop:
-ncs --stop &
-ncs-netsim stop
# stop ncs only...
stop_ncs:
ncs --stop
# start everything... (no resets)
start: start_netsim start_ncs
# start netsim alone...
#   -a option runs everything in the background (reduces the time to start or stop a netsim network)
start_netsim:
ncs-netsim -a start
# start ncs alone...
#   note: the --ignore-initial-validation option makes NCS skip any validation
#   callpoints when committing initial transaction (on first startup)
start_ncs:
ncs --ignore-initial-validation
# --------CLEAN code...
clean-ned-packages:
for i in $(NED_PACKAGES); do \
   $(MAKE) -C packages/$${i}/src clean || exit 1; \
   done
clean-cdb:
rm -rf ncs-cdb/*.cdb
clean-netsim:
rm -rf netsim
clean-state:
rm -rf state/*
clean-logs:
rm -rf logs/*
clean: clean-ned-packages clean-cdb clean-netsim clean-state clean-logs
rm -rf running.DB
rm -rf *.trace
rm -rf bin
rm -rf ncs-cdb/*.xml
# --------DEMO RESTART...
# use this to clean out CDB, netsim, etc. w/o re-compiling anything...
demo-restart: qstop clean-cdb clean-netsim clean-state clean-logs $(NETSIM_DIR) start
qstop-python:
pkill -f ncs-python-vm || true
qstop: qstop-python
pkill -f ncs.conf || true
pkill -f confd.conf || true
# --------RESET options...
# restart  [DeviceName]  This is the equivalent of 'stop', 'reset', 'start'
netsim_restart:
ncs-netsim -a restart
alam.bilal
Also take a look at "ncs-project" tool. One stop shop for setting up a project, downloading and building the packages, creating and starting NETSIMs. It automatically sets up the required makefiles to build, clean, start (NETSIM, packages, NSO etc).
