How to do nested loop in lux
spudukko
i have tried to nest a loop within another loop in lux with two end loops.  But i got an error saying end loop missing.
    [loop i 1..$max_time]
          [loop j 1..$min_time]
          [endloop]
    [endloop]
frjansso
You can work around this using a macro:
[macro inner]
[loop j 1..2]
!echo $j
[endloop]
[endmacro]
[shell test]
[loop i 1..2]
!echo $i
[invoke inner]
[endloop]
frjansso
[macro inner]
[loop j 1..2]
!echo $j
[endloop]
[endmacro]
[shell test]
[loop i 1..2]
!echo $i
[invoke inner]
[endloop]
Yes thanks for the reply. Thats what i ended up doing like the example in lux repo and like you showed using a macro. But was wondering if there any support for direct nesting
lux/loop_deep_fail.lux at master · hawk/lux · GitHub
