How to generate webui NSO actions audit log
cnicasio
As far as I know, all CLI operations are logged to audit.log. That includes service modification, and executing NSO actions.
However, if this operations are done using the webui, I don't find a way to audit log these operations.
There is an ncs.conf setting, audit-log-commit, that helps a bit for CDB modifications, but is of no help for the case of NSO actions.
Any suggestions?
perander
Is the ncs.conf setting /ncs-config/webui/audit enabled? It's disabled by default.
perander
From ncs.conf(5) man page
/ncs-config/logs/audit-log
audit-log is an audit log recording successful and failed logins to the
NCS backplane and also user operations performed from the CLI or
northbound interfaces. This log is enabled by default. In all other regards
it can be configured as /ncs-config/logs/ncs-log. This log is not rotated,
i.e. use logrotate(8).
What is it that is not logged in the audit log?
In particular, what action performed from the CLI is logged but the corresponding
action performed from the webui is not logged?
This is audit.log after doing a "re-deploy dry-run" from GUI:
<INFO> 18-Nov-2021::10:41:41.565 nsod-ap01 ncs[10752]: audit user: admin/0 logged in via webui from 172.28.44.143:58380 with http using local authentication
<INFO> 18-Nov-2021::10:41:41.566 nsod-ap01 ncs[10752]: audit user: admin/1667 assigned to groups: ncsadmin
<INFO> 18-Nov-2021::10:41:41.566 nsod-ap01 ncs[10752]: audit user: admin/1667 created new session via webui from 172.28.44.143:58380 with http
<INFO> 18-Nov-2021::10:42:06.587 nsod-ap01 ncs[10752]: audit user: admin/1667 NCS service-out-of-sync Service '/services/vrf:vrf_container/vrf{xyz}' Info ''
There is almost no info. For example, we don't which action was run, nor its input parameters.
perander
Yes! that was the issue. Thanks a lot for your help!
