how to get configurations which NSO send to device.
haofan
Level 4
Level 4
Hi expert,
     I use once rest api request to config static route, interface and so on. I use xml as rest payload. I want to get device cli configurations that NSO send to device. I know can use show command to get device cli command configurations, but sometime this method need take much  more time, so my question is that whether NSO could expose rest API that could get configurations whitch NSO send to device for every REST request ?
here is a case using XR device (netsim)
(equivalent of NSO "set devices device xr0 config: "
I used this command w/ different settings (native/cli/xml)
curl -i -u admin:admin \
http://localhost:8080/api/running/devices/device/xr0/config/\
cisco-ios-xr:interface/GigabitEthernet/0%2f0%2f0%2f2/ipv4/address/ip?dryrun=native \
-X PUT \
-H "Content-Type: application/vnd.yang.data+json" \
-d '
  "tailf-ned-cisco-ios-xr:ip": "10.4.4.4"
netsim: (original device config)
xr0# show running-config interface GigabitEthernet 0/0/0/2
ipv4 address 10.2.2.2 1.1.1.1/30
exit
xr0#
Now... using REST... and "native"
GSCHUDEL-M-61C2:LabDir45 gschudel$ curl -i -u admin:admin \
> -X PUT \
> -d '
HTTP/1.1 200 OK
Server:
Date: Mon, 11 Dec 2017 20:10:20 GMT
Last-Modified: Mon, 11 Dec 2017 20:09:39 GMT
Cache-Control: private, no-cache, must-revalidate, proxy-revalidate
Etag: 1513-22979-621847
Content-Length: 194
Content-Type: text/json
Vary: Accept-Encoding
Pragma: no-cache
{"dryrun-result": {
"native": {
"device": [
{"name":"xr0"
,"data":"\ninterface GigabitEthernet 0/0/0/2\n no ipv4 address 10.2.2.2 1.1.1.1/30\n ipv4 address 10.4.4.4 1.1.1.1/30\nexit\n"}
Now... using REST... and "cli"
GSCHUDEL-M-61C2:LabDir45 gschudel$ curl -i -u admin:admin http://localhost:8080/api/running/devices/device/xr0/config/cisco-ios-xr:interface/GigabitEthernet/0%2f0%2f0%2f2/ipv4/address/ip?dryrun=cli -X PUT -H "Content-Type: application/vnd.yang.data+json" -d '
HTTP/1.1 200 OK
Server:
Date: Mon, 11 Dec 2017 20:10:50 GMT
Content-Length: 458
Pragma: no-cache
{"dryrun-result": {
"cli": {
"local-node": {
"data":" devices {\n     device xr0 {\n         config {\n             cisco-ios-xr:interface {\n                 GigabitEthernet 0/0/0/2 {\n                     ipv4 {\n                         address {\n-                            ip 10.2.2.2;\n+                            ip 10.4.4.4;\n                         }\n                     }\n                 }\n             }\n         }\n     }\n }\n"}
Now... using REST... and "xml"
GSCHUDEL-M-61C2:LabDir45 gschudel$ curl -i -u admin:admin http://localhost:8080/api/running/devices/device/xr0/config/cisco-ios-xr:interface/GigabitEthernet/0%2f0%2f0%2f2/ipv4/address/ip?dryrun=xml -X PUT -H "Content-Type: application/vnd.yang.data+json" -d '
HTTP/1.1 200 OK
Server:
Date: Mon, 11 Dec 2017 20:11:04 GMT
Content-Length: 341
Pragma: no-cache
{"dryrun-result": {
"result-xml": {
"local-node": {
"data":"<devices xmlns=\"http://tail-f.com/ns/ncs\"><device><name>xr0</name><config><interface xmlns=\"http://tail-f.com/ned/cisco-ios-xr\"><GigabitEthernet><id>0/0/0/2</id><ipv4><address><ip>10.4.4.4</ip></address></ipv4></GigabitEthernet></interface></config></device></devices>"}
Hope that helps...
Cheers
gregg
gschudel
From reading the question, I assume you're trying to create a service-instance via REST, but would like to invoke "commit dry-run" and then select the outformat?
If this is the case, and assuming you can make the service-create REST call (with data in-line, from a file, XML or JSON -- makes no difference), just add the dryrun...
Here is an example REST call (XML from file), with dryrun=native
  curl -s -u admin:admin -X POST -T srvcExm1.xml http://127.0.0.1:8080/api/running/services?dryrun=native
you should be able to select native, cli or xml
you can find details at:
./nso-4.5.1.1/src/ncs/yang
tailf-ncs-services.yang
hope this helps
gregg
Hi gschudel,
     Thanks  for your replying, I doesn't use service rest api. I use device level rest api,  it looks like could use the same methods to get configurations. Example as below.
admin@ncs(config-fiber-node)# commit dry-run outformat native
native {
    device {
        name e8ba21ae-a0c8-344e-af08-32ec1dc79be8
        data ! Generated offline
             cable fiber-node 2
              downstream Downstream-Cable 7/0/0
              downstream sg-channel 0 15 downstream-Cable 7/0/0 rf-channel 0 15
              service-group managed md 0 Cable 7/0/0
              service-group profile tfchan_SG
-X PUT \
-d '
exit
xr0#
> -X PUT \
> -d '
HTTP/1.1 200 OK
Server:
Content-Length: 194
Pragma: no-cache
{"dryrun-result": {
"native": {
"device": [
{"name":"xr0"
HTTP/1.1 200 OK
Server:
Content-Length: 458
Pragma: no-cache
{"dryrun-result": {
"cli": {
"local-node": {
HTTP/1.1 200 OK
Server:
Content-Length: 341
Pragma: no-cache
{"dryrun-result": {
"result-xml": {
"local-node": {
Hope that helps...
Cheers
gregg
Thanks.  Got it.
