how to get upf status from nso cli rcm info using rest api
nisheeth
I am able to get the the rcm info from the nso cli using the command
adm_nsrivas37@ncs# devices device ORUD0403 live-status exec show rcm info
result
Redundancy Configuration Module:
Context:                         rcm
Bind Address:                    10.193.124.179
Chassis State:                   Active
Session State:                   SockActive
Route-Modifier:                  30
RCM Controller Address:          10.193.125.3
RCM Controller Port:             9200
RCM Controller Connection State: Connected
Ready To Connect:                Yes
Management IP Address:           10.147.13.173
Host ID:                         ORUD0403
SSH IP Address:                  10.147.13.174 (Activated)
SSH IP Installation:             Enabled
I am unable to get the same info using rest api it gives me error
curl --location --request POST 'http://localhost:8080/restconf/data/tailf-ncs:devices/device=ORUD0407/live-status/exec:rcm/_operations/show' \
--header 'Accept: application/yang-data+json' \
--header 'Authorization: Basic ########################'
Response
"ietf-restconf:errors": {
"error": [
"error-type": "application",
"error-tag": "invalid-value",
"error-message": "uri keypath not found"
I believe the issue is exec:rcm in the URI .
please let me know what will be the correct uri
Thanks and regards
Nisheeth
nisheeth
I did went thru the recommended examples and found the solution.
The URI had issues it was missing tailf-ned type and a payload. I added that and it worked below is the example.
curl --location --globoff 'http://localhost:8080/restconf/operations/tailf-ncs:devices/device=UPFd0407/live-status/tailf-ned-cisco-staros-stats:exec/any' \
--header 'Authorization: Basic ##############################' \
--header 'Content-Type: application/yang-data+json' \
--data '{
"input":
"args": "show rcm info"
Response
"tailf-ned-cisco-staros-stats:output": {
"result": "\nRedundancy Configuration Module:\r\n-------------------------------------------------------------------------------\r\nContext: rcm \r\nBind Address: #.#.#.#\r\nChassis State: Standby \r\nSession State: SockStandby \r\nRoute-Modifier: 50 \r\nRCM Controller Address: #.#.#.#\r\nRCM Controller Port: 9200 \r\nRCM Controller Connection State: Connected \r\nReady To Connect: Yes \r\nManagement IP Address: #.#.#.#\r\nHost ID: \r\nSSH IP Address: #.#.#.# (Activated)\r\nSSH IP Installation: Enabled"
6 Replies 6
huayyang
uri of actions under /devices/device/live-status/exec/ are encoded like RESTCONF/operations/tailf-ncs:devices/device=DEV_NAME/live-status/exec/ACTION
nisheeth
I am getting the error I dont know how to put show rcm info after exec
Request
curl --location --request POST 'http://localhost:8080/restconf/data/tailf-ncs:devices/device=ORUD0407/live-status/exec/"show rcm info"' \
--header 'Authorization: Basic ##################'
Response
"error": [
nisheeth
Earlier i was making the mistake and i corrected that still having error same issue how to put show rcm info because I am getting error invalid path
curl --location --request POST 'http://localhost:8080/restconf/operations/tailf-ncs:devices/device=ORUD0407/live-status/exec/"show rcm info"' \
--header 'Authorization: Basic ############################'
Response
"error": [
"error-tag": "malformed-message",
"error-message": "invalid path"
huayyang
I don't know how the action "show" is modeled, but probably the input parameter to "show" should be in a payload, check your ned model.
huayyang
there's some examples how to encode uri and action input parameters: https://datatracker.ietf.org/doc/html/rfc8040#section-3.6
nisheeth
--data '{
"input":
Response
