How to push configuration to UPF dir /flash/
nisheeth
I am working on the automation of pushing configurations to UPF
The configuration was committed to running config and it was working perfectly ok because it was not triggering the reboot
Now there is a new scenario
Add new interface for ipv6 and hten bind ipv6 and ipv4 in gtpu-service
config
context up
interface n3u_v6_loopback loopback
ipv6 address 2001::601/128
exit
interface n3u_v4_loopback loopback
exit
gtpu-service n3u-in
bind ipv4-address 10.10.10.20 ipv6-address
ipv4-address 10.10.10.20/32 ipv6-address 2001:0000:0000:0000:0000:0000:0000:0601 bearer-type all
exit
The problem is that if i commit to running config it will trigger reboot of UPF.
To avoid the reboot i need to copy the configuration to the configuration to the UPF in /flash directory
then take  mw to reboot
I need to know to how to add the config to the /flash file
Thanks and Regards
Nisheeth
0 Replies 0
