10-13-2017 05:47 AM - edited 03-01-2019 04:01 AM
Hello All,
I am trying to build a netconf ned for a ISR4331 router but with no success so far.
I have downloaded the yang files from the device and performed a dependcy check (that is OK for the 266 yang files).
When I run the command build-netconf-ned command, it first starts saying:
Ignoring NCS-internal module "iana-crypt-hash.yang"
Ignoring NCS-internal module "ietf-netconf.yang"
Ignoring NCS-internal module "ietf-netconf-acm.yang"
Ignoring NCS-internal module "ietf-netconf-monitoring.yang"
Ignoring NCS-internal module "ietf-netconf-notifications.yang"
Ignoring NCS-internal module "ietf-netconf-with-defaults.yang"
Ignoring NCS-internal module "ietf-yang-smiv2.yang"
Ignoring NCS-internal module "tailf-acm.yang"
Ignoring NCS-internal module "tailf-common.yang"
Ignoring NCS-internal module "tailf-common-monitoring.yang"
Ignoring NCS-internal module "tailf-common-query.yang"
Ignoring NCS-internal module "tailf-netconf-inactive.yang"
Ignoring NCS-internal module "tailf-netconf-monitoring.yang"
Ignoring NCS-internal module "tailf-netconf-query.yang"
Ignoring NCS-internal module "tailf-netconf-transactions.yang"
Ignoring NCS-internal module "tailf-rest-error.yang"
Ignoring NCS-internal module "tailf-rest-query.yang"
Ignoring NCS-internal module "tailf-webui.yang"
Ignoring NCS-internal module "tailf-xsd-types.yang"
And then, ends up with an error saying: augmented/tailf-confd-monitoring@2013-06-14.yang:65: error: grouping 'live_ncs_common-monitoring-objects' in module 'tailf-common-monitoring' not found
Any tip to avoid ignoring the tailf files?
Thank you for your precious help.
EDIT1:
It seems that this issue comes from the fact that the ISR4331 embeds an IOS XE that offers four views (SNMP, Native, OpenConfig and IETF). Following Jan's advice in his post, I have chosen the Native view.
However, the file cisco-ia.yang seems broken, does this matter?
Thank you!
Solved! Go to Solution.
11-20-2017 12:50 AM
You need to disable cisco-ia.yang to make the NED work. It contains functionality to configure and work with the NETCONF subsystem, so nothing you'd normally have to touch for automation use cases.
11-16-2017 08:12 AM
What version of NSO are you using?
-Dan
11-20-2017 12:50 AM
