in NSO HA (tailf-hcc), failover-master template isn't applied
yeepsae17
I'm testing the NSO HA - BGP Anycast (L3) method, everything works as explained in the tailf_hcc.pdf except failover-master.
The SLAVE moves to MASTER, not to FAILOVERMASTER, and the failover-master templates is not applied to slave's quagga device, even the master template is not applied!!!!  only the state is changed.
(please find attached log for the details)
Actually, I looked over the tailf-hcc package code and there's no FAILOVER-MASTER state in the HaStateType definition.. there are only NONE, SLAVE, MASTER, SLAVE_RELAY...  How can a node move to FAILOVER-MASTER state?
Please guide me to right direction!
the configurations are following..
root@ncs# show running-config ha
ha token kilskils
ha local-user root
ha interval 3
ha failure-limit 3
ha bgp failure-limit 3
ha bgp anycast-prefix 2.2.2.2/32
ha bgp anycast-path-min 1
ha bgp clear-enabled true
ha member nso-2nd
address 192.168.124.210
default-ha-role slave
failover-master true
quagga-device nso-2nd
ha member nso-kils
address 192.168.124.209
default-ha-role master
quagga-device nso-kils
root@ncs# show running-config devices template hcc*
devices template hcc-failover-master
config
quagga-bgp:hostname FAILOVERMASTER
quagga-bgp:route-map SET-MED 10
operation permit
set metric 10
devices template hcc-master
config
quagga-bgp:hostname MASTER
operation permit
set metric 12
devices template hcc-none
config
quagga-bgp:hostname NONE
operation permit
set metric 20
devices template hcc-slave
config
quagga-bgp:hostname SLAVE
operation permit
set metric 15
root@ncs# show ncs
ncs-state patches patches-directory /opt/ncs/current/lib/ncs/patches
ncs-state version 4.7
root@ncs# show packages package quagga-bgp
package-version 4.0.1
description "NED package for the Quagga BGP daemon"
ncs-min-version [ 4.2.2 4.3.0.2 4.4.2 ]
directory /var/opt/ncs/state/packages-in-use/1/quagga-bgp
component quagga-bgp
ned cli ned-id quagga-bgp
ned cli java-class-name com.tailf.packages.ned.bgp.QuaggaBgpNedCli
ned device vendor Quagga
NAME VALUE
show-tag hostname
entitlement-tag regid.2015-10.com.cisco.quagga-bgp-NED,1.0_3aefd7ee-0b72-4598-907d-c44d407949d5
build-info date "2018-09-19 06:44:32"
build-info file ncs-4.7-quagga-bgp-4.0.1.tar.gz
build-info arch linux.x86_64
build-info java "compiled Java class data, version 51.0"
build-info python ""
build-info erlang ""
build-info package name quagga-bgp
build-info package version 4.0.1
build-info package ref 4.0.1
build-info package sha1 fdce3f5
build-info ncs version 4.7
build-info ncs sha1 ""
build-info dev-support version 1.0
build-info dev-support branch 270f126
build-info dev-support sha1 270f126
oper-status up
root@ncs# show packages package tailf-hcc
package-version 4.3.2
description "Package for Tail-f HA Cluster Control Interface"
ncs-min-version [ 4.2 ]
directory /var/opt/ncs/state/packages-in-use/1/tailf-hcc
component TcmCmdDp
callback java-class-name [ com.tailf.ns.tailfHcc.TcmCmdDp ]
component tailf-hcc
application java-class-name com.tailf.ns.tailfHcc.TcmApp
application start-phase phase2
oper-status up
root@ncs#
Jan Lindblad
As you noted yourself, there is no state called FAILOVERMASTER. This is just a hostname used in the examples to keep track of which device is in which state.
