Inserting variable in xpath using python maapi
nso20
I was able to insert variable in xpath using python maapi but not for all parameters as below:
myname = 'cisco'
myinterface = 'GigabitEthernet'
mynumber = '1'
with ncs.maapi.Maapi() as m:
    with ncs.maapi.Session(m, 'admin', 'python'):
        with m.start_read_trans() as t:
            root = ncs.maagic.get_root(t)
            mydevice = root.devices.device[myname]  -- ok
            interface = devs.config.ios__interface.GigabitEthernet[mynumber]  -- ok
            interface = devs.config.ios__interface.myinterface[mynumber]  -- NOT ok, tried myinterface with square/curly brackets but no luck.
Can you assist ?
2 Accepted Solutions
vleijon
The basic problem is: How would Python know that GigabitEthernet is a reference to a field, but myinterface is a reference to a variable that should be resolved? Python solves this by always assuming it is a field reference. You do, however, have a function getattr that you can use.
Something like this works:
def ifindepend(device, iftype, ifnum):
    with maapi.single_read_trans('ifindepend', 'system') as t:
       device = root.devices.device[device]
       interfaces = device.config.interface
       interfacetype = getattr(interfaces, iftype)
       interface = interfacetype[ifnum]
       print("IF: {} {}".format(interface, interface._path))
vleijon
Yes, that is expected, since that is the name of the list we are in. You can use that _path to get the full path, or just keep grabbing elements under it as normal.
vleijon
But print(interface) displays GigabitEthernet only, not GigabitEthernet5 ?
vleijon
